Marshall JCM2000 TSL601 Powers on but no sound
  • thom3331 Mar 24, 2009
    Same problem, took it to my tech. He said the JCM2000 series all have this problem, he said he fixes them all the time. It's something with the heater filiments or grid resistor or something. He said he doesn't understand why marshall didn't fix this problem a long time ago! Easy fix,... take it to your tech!! ;)
  • 1,512 Answers
Hi scot4321
Most common cause of no sound is a blown fuse. Check both the fuses with a resistance checker if you have one, sometimes they may look good, but be faulty. If this is the case, you probably need to look for a reason why the fuse blew in the first place. Running a tube rig without a speaker connected is often the problem. the HT fuse will pop almost straight away. Another is using a signal lead instead of a speaker lead to connect your Speaker cab. Always use at least an 18 gauge speaker lead with decent connectors like Switchcraft or Neutrix. NOT a cheapo patch lead. A Failing tube will also commonly cause it to blow. If it happens again, then change the output tubes. If it is not the fuses, and you have experience with repairing valve amps, I suggest you take the head into a repair guy for a look.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you still have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 31, 2008
Marshall jcm2000 tsl combo turns on but no sound from any channel
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
Sep 04, 2014 | Marshall Amplification Music
Yesterday, I accidentally switched off the powerstrip which my 100 Watt JCM2000 DSL is plugged into. I immediately turned it back on, without shutting off the power, and heard a "POP" I then tested the...
It is unlikely that your actions with the plug strip caused any permanent damage to your unit.
If you unit has a digital effects unit, probably the setting for that got disturbed and you need to reset it to your desired setting.
Jan 18, 2010 | Marshall Amplification Music
My problem is that the clean channel doesn't work. The OD1/OD2 channel works just fine but I'm not getting any sound out of the clean channel... any ideas?
Here is the schematic:http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf There are a few possibilities.The jack for the footswitch for channel changing JS1 might be faulty. Zener diodes 1 and/or 2 might be faulty. Switch 2 may be defective. TR1 might be defective. IC 4 or 5 might be defective.Start with the channel switching circuitry testing in the order I gave you. Check the actual clean channel circuitry to see if you actually have a clean channel anymore. Before you do any of this make sure you know enough about troubleshooting and have at least a good VOM and are familiar with safety procedures. The filter capacitors in this amp store enough charge to kill you. A cheat to partially discharge them without damaging the amp is to unplug it from the wall while it is hooked up to the speaker cab you are using while it is on at a very low volume with a guitar cord plugged in. Make sure you use exact replacement parts if you tackle this. They don't have to be from Marshall, they just have to be exact electronic equivalents from a quality manufacturer installed correctly. I would recommend that if you have no experience or are at all unsure of the repair to take it to a Marshall dealer to have it done. Please rate me if this helps.
Nov 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Replacing power amp valves for Marshall JCM2000 TSL122
Unless you have experience working on tube amplifiers and all the necessary test equipment you should spend the money and have this done by a qualified electronics technician who has experience particularly servicing tube amplifiers.
Nov 05, 2009 | Audio Players & Recorders
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Nov 05, 2009 | Marshall Amplification Marshall MG250DFX...
JCM2000 DSL100 No Sound
Not likely to be a fuse. The bane of electrical amps are the connectors.
Often the speaker and more commonly the input 1/4 inch connectors go bad. Sometimes caused by side loads when cables are yanked or tripped over.
Be careful of running amps IF the speakers are not connected OR have bad connectors or cables. You can arc over the tubes or pop transistors.
Get a cheap Volt-ohmeter from HarborFreight or Radio Shack and test your cables and connectors.
For a tube amp, your should find relatively low resistance at the speaker connector (certainly under 20 ohms). Do this with power off.
Sep 09, 2009 | Marshall Music
My marshall jcm2000 dsl50 will not power itself the mains lead is fine and none of the fuses are blown but it wont power i have only had it four months why is it doing this.
Check standby power supply,it stays on all the time main power is off and is subject to damage from transits from power company.Bad switch?
Sep 07, 2009 | Marshall Music
No output
There are some possibilities. One, your speaker may be blown or disconnected. Make sure the wiring is still connected to the speaker and if you have one, try measuring the resistance(impedance) of the speaker with a volt ohm meter.Do this unplugged from current and disconnect one of the wires from the speaker or you will get a reading from the output stage. Two if there is a heaphone or line out jack it may have become faulty. If you have sound with the headphones plugged in your amp is still producing sound. Some jacks are designed to interrupt the signal to the speakers allowing you to practice without bothering anyone. If your amp has that feature and you still have sound with the headphones and your speaker tests OK then your problem is the jack. Hope this helps.
Jul 20, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
711 people viewed this question
 Grubhead
Grubhead
