Question about Aqua Vac Tiger Shark
I have a tiger shark one and half years old. it turns on, can hear the motor going and it will move and clean regularily anywhere from 20 sec to 5 minutes. but then will get stuck in one spot. the motor is pushing water out through impeller but the wheels are not turning and it is not moving. what to do? when i take it out, the wheels manually move well both ways.
    President:
  • Aqua Master
  • 1,378 Answers
The motor pack is having trouble and will need to be replaced (most likely). For help finding a service center that can perform the inspection and repairs check Hayward's site at http://www.haywardnet.com/locator/ and fill in the information requested. Be sure to select product repair or service and robotic cleaners to limit the response to those able to fix these cleaners. We are in S.E. Michigan and are one of the centers for Tiger Shark cleaners.
John
Posted on Oct 11, 2010
  • QtipC Jul 28, 2011
    I'm having the same problem. Tiger Shark worked great a couple days ago. Went to use it today and it doesn't move. I have power. How much does a motor pack go for. There are no service centers located in my area. What are my options.
Why does my tiger shark motor run and peller spins but wheels do not turn
if the wheels are not turning, there is a good chance the drive belt is damaged. this can be repaired
Jun 14, 2014 | Aqua Vac Tiger Shark
Tiger Shark moves slow
no tension need to replace tracks
Jun 25, 2012 | Aqua Vac Tiger Shark
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Jul 23, 2011 | Aqua Vac Tiger Shark
UNIT BELONGS TO A FRIEND ONE OF THE DRIVE BELTS WAS BROKEN. SHE GOT ONE AND SOMEONE ELSE TRIED TO REPLACE IT BUT WAS UN ABLE TO . I REPLACED THE BELT AND TEST RAN IT ON THE WORK BENCH IT WORKS BUT ONLY...
Try it in the pool...the unit is not going to run for more than a short test cycle on the bench since it know there is no water present and running it dry can overheat the motors and cause them to fail permanently.
John
Apr 18, 2011 | Aqua Vac Tiger Shark
My tiger shark pool cleaner will run for about 30 sec. then shut off. how can i fix this problem?
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
Aug 18, 2010 | Aqua Vac Tiger Shark
Tiger shark just doesnt clean very well
I the filter is not very clean the pump will not push hard enough to hold the tracks onto the walls. Try running without filter in a very clean pool for a few minutes to see if it solves the climb walls replace the filter and clean the unit
May 26, 2009 | Aqua Vac Tiger Shark
Have power to the floating cord but tigershark will not run.
My tigershark would start working then stop 20 seconds to 20 minutes later. I found that the power switch was loosing good connection after self check cycle, I turned it on and off rapidly to hopefully clean the contact! I now disconnect and restart by pulling the power cord. I have run two cycles with no problem> I will replace the switch when I get a chance.
Good Luck
Apr 25, 2009 | Aqua Vac Tiger Shark
Aqua Vac Tiger Shark Logo
1,075 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
