Question about Poulan "" Push Mower
Cannot get started after has started all summer changer spark plug and cleaned air filter Only problem is that also overfilled oil reservoir will that keep it from starting? If so how can i get some oil out ? Is there a drain plug?
  • 26 Answers
Hi pt--
If you are certain the oil is overfilled, then yes, this should be the problem. Single cylinder engines have little tolerance for excess oil in the crankcase. Since you're at it, you may as well change the oil in the mower while you have this all apart. In order to do this safely, be sure you have disconnected the spark plug wire from the top of the plug. You do not want the mower to start while you are under it. If you are unsure, ask someone who knows how to do this safely. You should also do this on a cool mower, as gasoline could leak from the tank or carburetor and pose a burning and fire risk. That said:
To change the oil on a single-cylinder lawnmower:
1) Gather materials.
--You'll need a pan or an old bucket to catch old oil, preferably one that has enough capacity for the old oil while also allowing the mower to be positioned with all four wheels on the ground.
--Some rags.
--A set of wrenches or a socket set.
--Two fresh quarts of new motor oil of the recommended viscosity for your particular lawnmower.
2) Disconnect the spark plug from the ignition wire. You'll see a cable running to the top of the spark plug. Grab it firmly at the boot that sits atop the plug and pull firmly. If it doesn't come off easily, be sure you are pulling at the right spot.
3) Tip the mower either backwards or on its side and look underneath the cutting deck. Be careful, as gasoline may spill from the engine's tank. You should see a small square-head or hex-head plug directly below some point of the engine. That is the engine's oil-drain plug. CAUTION: You may need to rotate the cutting blade to gain access to this plug. Be aware that the blade can cut you and that if the mower starts now it can cause serious injury to yourself.
4) Locate the correctly sized wrench or socket that mates to the drain plug.
5) Using a correctly sized wrench or socket, carefully and slowly loosen the drain plug until it turns freely by hand.
6) Position your drain pan beneath the engine's drain plug.
7) Unscrew the drain plug by hand until the oil drains free. Setting the mower down on level ground with all four wheels will ensure the most old oil drains from the engine at this point. Go ahead and open the engine's oil fil cap at this time, as this also allows the oil to drain freely.
8) When the oil has stopped draining from the engine--usually a slow drip is ok--you can replace the drain plug by hand. Be sure the plug turns freely by hand--do not crossthread the plug as you will create a costly repair for yourself.
9) Tighten the plug snug--NOT samson tight--with the correct wrench or socket and wipe any oil present at the plug or surrounding area clean with a rag.
10) Remove the pan from below the mower and rest your mower on all four wheels.
11) Slowly fill the mower's cranckase to full with fresh motor oil. Often, less than a single quart is necessary. Go slow and do not overfill.
12) Tilt the mower backwards again and check for oil leaks at the plug. You may need to snug up the oil drain plug one more time before the first after-oil-change start.
13) Lower the mower, reconnect the spark plug, and start the mower. Let it run for about a minute and listen to the mower for any "bad" sounds. If you hear anything out of the ordinary, shut off the mower immediately and recheck the mower for abnormalities.
14) Shut the mower off.
15) Check the oil level. You may have to top off the fluid level again, as running the engine tends to let the fluids settle out.
16) Disconnect the spark plug once more.
17) Tilt the mower and check the drain plug one more time for leaks. Snug it up as necessary.
18) Let the mower back down to the ground and reconnect the spark plug to the ignition wire.
You should be ready to mow again. Remember to be aware of any oil drips as push the mower around after a recent change--that may indicate the plug is leaking. There is a great picture of what a mower's drain plug looks like in the link below. Just scroll down to the part where you see the picture labeled 'oil drain plug.'
http://floridagardener.com/misc/tuneup.htm
--Hope this helps, Joe.
Posted on Oct 10, 2010
Toro 418 zr snow blower was smoking prior to last use. Doesn't start now.
Was it blue or black smoke? Did you change the oil and overfill it? Is the choke stuck on? Blue smoke is oil burning and black is too much gasoline. Did you tip it over? If you tip it it will make oil go into the valves and pistons.Pull your spark plug and see what it looks like May need replacing as well. Is your air filter clean? All these could effect how it starts and runs.
Dec 21, 2016 | Garden
Overfilled lawn mower and now it is will not start.and when i try to start it it start for 2or 3 sec and stall out and oil come out of the exhaust.
Overfilled with gas or oil? More in likely you tilted your mower over to far to the air fllter side. The oil has soaked your air filter with oil. Change the airfilter and wipe spark plug off.Once it fires up it will smoke untill it burns the oil out carb. Remember never lean mower to air filter side..Good luck
Aug 17, 2013 | Garden
I overfilled engine oil in my Briggs Straton engine on my snow thower ... now can't get it started .... can oil foul the spark plug ?
Hi and welcome to FixYa, I am Kelly. Depending on just how much you over-filled it yes it will fowl the spark plug. Most of the time though a small engine failing to start is either fuel or ignition related. Remove the spark plug and check for ign. spark and OIL in the cylinder by pulling the recoil through. Reinstall the spark plug (Just a note about an oil fouled spark plug.... if you clean it with fuel you must make sure that it is dry or it will not work. Spark plugs are cheap I recommend you buy a new one.
Try removing the air filter and adding just a small splash of gas into the carb. throat. then see if it tries to start. If it does but does not run you have a fuel supply problem. This is caused by debris in the carb bowl and fuel orifice jet. You will need to clean out the bottom of the carb and the orifice. Possibly there is debris in the fuel tank outlet, the fuel filter or fuel bowl below the fuel selector depending on your engine model. .I can help you with carb / fuel system cleaning procedures but would like a "complete" ENGINE model - type - and serial number so I can pass you the procedures applicable to YOUR engine.
Thanks for choosing FixYa,
Kelly
Jan 27, 2011 | Garden
Why would a spark pluf get fouled in less than a minute of starting on a briggs mower engine?
If there is a great quantity of blue smoke from the exhaust, then oil is entering the combustion chamber. The oil reservoir may be overfilled considerably, or the engine was laid on it's side for some time and oil filled the valve spring area which allowed the oil to pass through the intake valve guide when started. You should be able to clean the plug with spray carburetor cleaner each time it fouls out until the oil source is determined and repaired or cleaned. Hope this helps!
Oct 30, 2010 | Garden
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas...
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Oct 13, 2010 | Craftsman Garden
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Oct 12, 2010 | Briggs & Stratton Garden
It wont start. Fuels good. Gets a spark, although plug looks oily. Air filter was dirty, have new one. Still wont start with filter off. Tried starter fluid. Manual says maybe excess oil in engine. If so,...
If you have no sign of life with starter fluid, there's no spark in the cylinder.
If the plug is oily, it may spark in free air, but not under compression. Try a new plug first.
Excess oil won't prevent the engine from starting, but it will spew oil everywhere if it's overfilled. Just check the level with the dipstick (on level ground), and pour any excess out of the filler tube.
Aug 07, 2010 | Briggs & Stratton 190cc 875 Series OHV...
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
Many times a dirty air filter will cause this on this style of engine. When the filter is plugged, it creates a 'rich' fuel condition, and the engine smokes heavily, the excess carbon is drawn into the air filter, and plugs it even more.
check spark plugs, air filter, fuel filter, choke linkages (for full choke/no choke operation) and crankcase oil.
Crankcase oil can become fuel contaminated, thus overfilling the crankcase and filling the crankcase breather with raw oil/fuel, and this is drawn into the air filter, plugging it, and starting this senerio.
If there is fuel in the crankcase oil, drain completely, and refill with fresh oil. Then you need to look towards the carb for an inlet needle sticking, broken, worn.
Nov 15, 2009 | Craftsman Garden
Why does my craftsman rider blow out black smoke and spit and spudder? I changed the oil and filter.
could be any number of things - when you changed the oil, was it really runny? was it way overfilled? if runny, possibly the carburetor inlet needle is not shutting off and gas is flooding the crankcase. overfilled? older kohlersmeasure oil level without screwing dipstick in. puking oil into the air filter housing? could be a blown head gasket. OR, it could be as simple as a bad spark plug, it DOES happen
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Poulan "" Push Mower Logo
436 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
