Question about Frigidaire FEQ1442ES Electric Dryer
When dryer starts running there is a scratching noise that is causing the belt to work harder and omit a smell. How do I remove the drum I have vacumned and cleaned the back and the bottom of the dryer.
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley or maybe your drum has worn thru the felt seal where the drum and door meets.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Be sure to check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
This is a FREE answer, Please rate me
Posted on Oct 10, 2010
I have a frigidare dryer 5-6 years old. Recently, started smelling like something electrical is burning. If I hold down the start button the motor will turn the drum slowly and the burning smell returns....
Check for vent blockages! Overheating may be a serious issue and fire hazzard. A slow moving drum could mean a bad traction belt, jammed mechanical part or the motor is not spinning at a proper RPM which may indicate motor damage also. The electrical burning is a serious issue also and a fire hazzard. Dryers need periodical cleaning to remove excess lint, dust and debris. Lack of cleaning causes the dryer to work harder and run hotter. Excessive heat shortens the life of many parts such as belts, bearings, electronics, wiring, etc...
Sep 21, 2012 | Dryers
Not spinning, although making sound like working. It was heating though and burning smell
Hi allburnedout...
I think your belt is slipping or broken and causing your burning smell...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me
Aug 15, 2011 | Frigidaire Dryers
THE DRYER MAKES A LOUD GRINDING TYPE NOISE AND THERE IS A BURNING SMELL WHEN IT STARTS
Sounds like you have two problems cause by one problem.
Your noise is coming from your drum rollers needing oil and the smell is cause by the drum belt slipping because of the added pressure to try to turn the dry drum rollers.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
pulley and motor.
Check your drum rollers for flat spots or wear, if they have flat spots
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 24, 2010 | Dryers
Dryer starts but drum does not turn. was fine until a sneaker got wedged between one of the fins and the chamber wall and drum stopped turning and we smelled a burning odor. after removing the sneaker we...
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Oct 02, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer smells like burning rubber when i open the door
Sounds like your problem may be the belt has slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn and produce a burning rubber smell.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 30, 2010 | Hotpoint NVL333EY Electric Dryer
Dryer makes noise that sounds like tumbling glass and smells hot
Good luck,
I hope this helps
Thank you
May 19, 2010 | GE DBSR453EBWW Electric Dryer
When I start the electric dryer, there is a burning smell. Before it wouldn't start and I clean everything inside and now it starts but there is a burning smell and don't want to use it if going to start...
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
Good luck,
I hope this helps
Thank you
May 13, 2010 | Whirlpool GEW9200L Electric Dryer
Burning smell - like rubber - dryer does work though
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps
Nov 19, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer hums without spinning. Held door switch and started drum spinning while pressing start. Dryer ran for a couple seconds then thermal overload kicked in and shut power off. Really hot smell came...
Sounds like your problem may be a broken belt, or the belt may have slipped off of the idler arm pulley or motor.
If you have to replace/reinstall your drum belt and if you have a front loading machine.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Good luck,
I hope this helps
Oct 27, 2009 | Estate TEDX640JQ Electric Dryer
My dryer stopped spinning and its making a terrible noise/smell
Sounds like you have a broken belt.
First you will need to unplug your dryer from the electric.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
The smell your smelling is probably from the heating coil not getting air over it to send to the drum to dry your clothes, this should go away after you replace the belt and get the blower to turn again.
Good luck,
I hope this helps
Oct 08, 2009 | Whirlpool LER4634J Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
59 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
