Question about Brother HL3070CW Compact Digital Color with Wireless Networking Laser Printer
I recently purchased a Brother HL- 3070CW printer and installed it on a home network. The network is set up as follows: 1) Router - Belkin Play Max N 2) Desktop - Windows XP Home Edition - Wired 3) Laptops (2) - Windows 7 - Wireless Connections I have repeatedly run the set up for printer trying both wireless and wired setups using the Brother set up software. In all instances I leave the set up process with all indications that the set up was successful, but so far over the past several days - of experimenting - I have only printed two pages. Additional info: I have checked the IP address for the printer both at the router and the printer - they are the same There do not appear to be any IP address conflicts I can ping the printer from the PCs and have even gotten access to the the printer menus via the network But the bottom line is that even though everything seems to indicate "connected" nothing seems to be getting through - except in those two instances I mentioned previously.
  • 3 more comments
  • wtoombs1 Oct 10, 2010
    There are no IP conflicts and the gateway is set up correctly as indicated in the printer settings.
    Thank you for the suggestion, but I tried that and I am still not getting anything to print. Previously I had been working from the wired desktop - with the XP operating system. Today, after your suggestion, I tried the process from one of the laptops - Windows7.
    I have access to the router and have confirmed that DHCP is enabled.
    I should add that I currently set the printer up as a wired peer-to-peer
    printer in the router. (Ethernet cable plugged into both devices.)
    Printer is still not responding.
    I have set and confirmed all of the items previously suggested.
    There are no IP conflicts on the router.
    DHCP is enabled
    The printer indicates that it is connected.
    I have hooked up an ethernet cable and set the printer up for a wired network connection.
    Thank you for the response, but you may have to do more explaining regarding opening ports. I have some experience with setting up PCs but have never gone into that area.
    I have confirmed that both the Pc and the printer are expecting to "talk" via the same port - if I am to believe the name they are providing.
    Incidentally, have I mentioned that periodically (three times now) something will print out. In each case it is a document that I have sent to be printed some time previously and had been told - in the PC that there was a problem. In each of the case I am sure that I deleted it from the print menu.
    But they still ended up being printed. Usually when they print I think that I have somehow stumbled upon a solution. That has not proved to be the case, however.
    A question?
    The router is working at 2.5GHz and 5GHz
    On the first it says the wireless channel i set to 4 with the extension channel being 8
    On the second the wireless channel is "auto" and the extension channel is 40
    The printer indicates that its Channel is 4 with the receiving channel being 3.
    I have no idea if that information is critical, but am including it just in case.
  • 2,973 Answers
Your networking is fine as you can see the printer on all computers. It seems to be a driver related problem. Please follow the link below to un and re install the printer on all computers following the link below:
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Oct 11, 2010
  • 11,800 Answers
For the printer to work some ports must be opened both in the router and in the pc's: LPD ("printer") on port 515, IPP on 631, and PDL-datastream on 9100.. Make sure of that. For diagnostic purposes try first with all the firewalls shut down.
Posted on Oct 10, 2010
  • Azrael SRL Oct 11, 2010
    Normally the receiving is done in the same channel - the fact that the printer expect that on a different one might be the cause why it doesn't work. Change it back to 4.
    Here you can find a good tutorial on how to open and forward ports in pc's and the router. http://forums.afterdawn.com/thread_view....
  • 4,281 Answers
Same ip address creates problem in network. Make sure that your printer ip address is different from another ip address of computers. Set gateway as your router ip in all computers. Then check. Let me know if you need further assistance. Thanks for using FixYa.
  • If you get ping of printer ip address on all computer then only need to uninstall printer driver then reinstall.
    For that go to control panel uninstall printer driver from there then reinstall printer driver.
    click on above link select your os and download driver then install.
    then it will work again.
    thanks for using FixYa.
  • Enable DHCP in router then on your computer go to local area connection tcp ip property and set "ip get automatic "
    For enable DHCP in router follow below direction.
    Connect your router to computer with ethernet cable then you can access it with following default link.http://192.168.1.1 orhttp://192.168.0.1 orhttp://192.168.15.1 orhttp://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then go to DHCP and enable it then save settings and restart router.
What are brother printers that take tn210 cartridges
Brother color machines use it:
Brother DCP Series: DCP-9010CN,
Brother HL Series: HL-3040CN, HL-3045CN, HL-3070CW, HL-3075CW,
Brother MFC Series: MFC-9010CN, MFC-9120CN, MFC-9125CN, MFC-9320CN, MFC-9320CW, MFC-9325CW
BR
Sep 29, 2017 | Brother Office Equipment & Supplies
Brother HL-3070CW burning smell
Did you run labels or paper the is not compatible with laser printers?
A label may be stuck on the fuser. There's not much you can do unless you know how to remove the fuser.
Oct 08, 2013 | Brother Hl-3070cw Digital Color Printer...
Printer HL-3070CW - LOUD Grinding noise when it seems to be running large print offs. It is almost like it gets too hot
My 3070CW makes the same noise. It is caused by the transfer belt. One roller is driven by a cog and this goes fine. The other roller has a tensioner and this roller is making all the noise. While the noise is really loud and annoying - it is completely harmless. Hope this helps.
Aug 09, 2011 | Brother HL 5250DN Laser Printer
Hi! I have a brother HL-2170W printer. It is connected via ethernet cable to a Dynalink RTA1046VW router (which is sitting on top of the printer) and I have a HP pavillion entertainment PC that is...
Hi!
Your Printer is connected to the (network) router via ethernet cable. Hence, it is a NETWORK PRINTER NOT A WIRELESS DEVICE, no matter your PC is connected to the network wirelessly. So, search for and install the printer as a NETWORK PRINTER. From the printer installation, it should searh and find the printer and susequently install the required drivers.
Moreover, you may checkout the followings link for instructions on how to install/ add a network printer.
LINK-1, LINK-2
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | Brother HL-2170W Mono Laser Printer
Our brother printer wireless hl 3070cw will not print, it is telling us that it is ready but will not print
it would have print archive in its job print .. check and delete . or install printer again .
i hope it shall work .,
Mar 29, 2011 | Brother HL3070CW Compact Digital Color...
We have 2 Brother printers (mfc-9880 and MFC-8860dn both on a LAN)and have just added a hl-3070cw also on the same LAN. The 2 MFC have always appeared on ''My Network Place'' but the new HL does not and...
You have to setup that printer from all clients as a network printer again... from each client, and print a test page from each too. Sharing must be enabled also, it must be installed with latest drivers, for whichever system.. Just set it up correctly and all will be good.
Mar 02, 2010 | Office Equipment & Supplies
Brother MFC Networking Problem with New Router
When you purchase a new router you must change your security settings to accept that program so it can be ran to work with your os please check your firewall settings to see if they are blocking any new router installs you can do this by selecting start-programs then go to security settings and check your network connections and settings for your security settings.
Oct 05, 2009 | Brother MFC-7820N Printer
Brother HL3070CW Compact Digital Color with Wireless Networking Laser Printer Logo
701 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
