Question about ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
I have a A8V-VM Ultra socket 939 with AMIBIOS 0903 version. When I boot normally with the Windows XP (SP3) on the hard disk it seems to work fine, nothing abnormal happens. Booting with a Ubuntu 10.04 (Lucid-Linx) CD is the same thing. Booting to the setup utility works fine. But if I try to boot with a XP (SP3) (The same installed in the HD) to do a reinstallation the machine shutdown unexpectedly in a few seconds (for example in the partition screen). If I try to boot without boot device (no disk, no diskette, no CD) the "Insert proper boot...." appears and the computer shutdow unexpectedly in a few seconds as with de XP CD. I try changing position of memory (I have two different ones and I left only one to avoid incompatibility problems). Thank you in advance for your attention.
    New Friend:
  • 4 Answers
Go into your bios settings make sure your hard drive is set to IDE and make sure secure boot isnt on. You could just try resetting to default.
Also check your ram. Take out one then the other. This usually happens when Windows loads the files it is about to install into the ram. It takes up a lot of space and could cause faulty ram to overload.
Posted on Mar 19, 2017
  • 147 Answers
SOURCE: not installing windows xp with asus k8v-mx motherboard
Sounds stupid but I have seen it happen. Make sure the cd in the first in the boot sequence in the set up. If that dont work make your c drive first. Give it a shot, may work..I love asus
Posted on Sep 23, 2008
  • 144 Answers
SOURCE: VIA Asus A8V Socket 939 Motherboard - K8T800Pro
try downloading drivers from this website http://www.amdboard.com/socket_939_boards.html
Posted on Jan 09, 2009
Suricatta
  • 92 Answers
SOURCE: disk boot failure insert system disk
Looks like your CD-ROM or DVD-ROM is damadged or flat cabel that connect it to Motherboard.
Replace it (Optical drive or flat cable) and you should be able to run from CD.
Best Regards.
If it helps, rate me !
Posted on Jun 25, 2009
  • 256 Answers
SOURCE: New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
bob_computer
  • 3153 Answers
SOURCE: Motherboard does not BOOT to windows
If you are running anything from windows XP upwards inc Vista
then you must re-install the operating system when you change the motherboard.
From your description that is the problem you are encountering.
You could place your windows disc in the cd rive and tell the computer to boot from that and try a "repair install"
If successful you will loose no date but will be asked to re-register with microsoft.
If your windows disk is original and not meant for an OEM computer that will not be a problem
Posted on Aug 30, 2009
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
How to go integrate pheripherals in bios mode in ABV_VMboard
The Asus A8V-VM motherboard?
Socket 939 processor socket, VIA K8M890 motherboard chipset, uses DDR Sdram at 400MegaHertz? (PC-3200)
http://www.asus.com/Motherboards/AMD_Socket_939/A8VVM/
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#AMD_.2F_Intel_processors
Motherboard Manual,
http://www.asus.com/Motherboards/AMD_Socket_939/A8VVM_SE/#download
[ + Manual (5)
Scroll down,
Version E2928
A8M-VM SE User's Manual for English Edition (e2928) ]
Page 17 - Standard Interrupt Assignments
BIOS Setup - Page 1 (43 of 86)
Advanced Menu - Page 18 (60 of 86)
PCI PnP (Plug and Play) - Page 27 (69 of 86)
Regards,
joecoolvette
Jun 02, 2012 | Computers & Internet
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
How can i get vga driver for asus a8v-vm motherboard
Go to asus.com and go to support and downloads driver and select appropriate modelnumber of your laptop and windows version and download it its simple
Apr 18, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
PC gets to "Starting Windows.." then suddenly restarts.
you may want to reinstall your operating system i know several people with this issue and it has worked fine just insert the cd of whatever os you choose then boot from it
Dec 24, 2009 | ASUS A8V-VM Motherboard
Jun 03, 2009 | ASUS K8V-MX Motherboard
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
ASUS A8V-VM SE (MB-A8VVMSE) Motherboard Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
