Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
When i try to use the reset button on my kenmore progressive vacuum, it is having no effect. The agitator brush still will not turn.
  • 377 Answers
Take the time to check to see if the belt that drives the brush is operating correctly. I would also see if the brush itself is frozen up and unable to move. You need to remove the brush in order to change the belt. It would be a good time to clean the brush of all debris and add some WD40 to the plastic tabs at the end of the brush. Add the WD40 and turn the tabs around the brush to make sure the turn freely. Reassemble with a new belt.
If you find this solution to be beneficial, a Thumbs Up rating from you would be appreciated. Paul
Posted on Oct 10, 2010
I caught a shoestring in the brush and now it won't turn. I pressed the "overload protector reset" button but it's just loose and seems to have no effect.
Hi. I think it may still need resetting. Keep pushing reset. If this does not help remove the brush the turn it on. It should start. If so, there still may be somethng in the brush bearing that is stopping it from turning. It could also be that the belt broke when you got the lace. Let me know please, hope this helps. Chris
Feb 21, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
I have a kenmore progressive upright vacuum can't find the reset
I would try turning the brush by hand to see if there is any resistance. I'm not aware of a "reset" switch that is end user accessible. If the vacuum still has suction, make sure you are using it on a carpet. The brush doesn't turn on wood or vinyl flooring.
Nov 05, 2017 | Kenmore Vacuums
Agitator doesnt turn
There is actually a reset button on the agitator, I would try pushing this switch first to see if this fixes it. The button is located on one of the sides of the agitator housing, I'm not sure if it's the left or the right side, or on the top of it.
Look on the sides of the part of the vacuum that is on the floor and see if you can see a small red pole on either side. If you can't find it here, look on the top of the part of the vacuum that touches the floor for a brush overload reset switch.
Try pushing that poll whenever you find it. This switch is a protection mechanism that will shut the brushes down to protect them if something gets vacuum up inside of the brush, it will automatically shut itself off to prevent any damage.
Simply push this overload switch down, and this should hopefully fix your problem.
If this didn't, please let me know and I can walk you through some more advanced troubleshooting.
If this was helpful, please be so kind and rate my repair, or leave feedback.
Thank you!
Chris Jones
GoVacuum.com
May 18, 2010 | Kenmore 31913 Progressive Direct Drive...
The brush has stopped turning when used in the upright position
I have one too and I'm trying to fix it as I write this.I also have an older version and I've had no luck.I've taken evey screw out ,spayed tweeked and tried everything possible.my solution would be to stay away from Hoover steam spin scrubs.I'm going to invest in one with brushes like a vacuum.Those that are easily replaced as well as the drive for it be it a belt or a turbine like I've read this unit has
Apr 20, 2010 | Kenmore 31913 Progressive Direct Drive...
The brush is not rotating
Try pushing the reset button with a pen or paper clip. If that doesn't work, the motor may need to replaced. If the reset button is stuck, I don't know how to fix it - mine has the same problem.
Feb 21, 2010 | Kenmore 31913 Progressive Direct Drive...
I have a model 116.35922 beltless drive vacuum. The agitator brush will not turn with the vacuum running and the handle down. The brush turns by hand and the reset button has not popped. Ther is nothing...
I just had the same problem. The roller will not turn if the unit is overheated. I discovered that my bag was too full. I changed the bag then the roller started turning again. I don't know if this is true cause and effect, but it couldn't hurt to try.
Aug 23, 2009 | Kenmore Vacuums
Brush won't turn
The Agitator Overload switch is located on the top of the base assembly. Unplug the vacuum and press the reset button. The vacuum also has thermal protection, which will reset itself once the vacuum cools. The agitator will also stop when the vacuum is in the full upright position.
35922 Owner Manual
Feb 08, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Agitator wont turn
Some of these have a resetable circuit breaker, if it has one, push it. There is a motor on the brush roll which could be bad. There also is an on/off switch, it may have a problem.Also may have a switch where the hose goes into, some models have a actuator for the switch, when the hose is pushed in, it actuates the switch so the brush roll motor turns on and stops when you pull the hose out.
Sep 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Agitator brush will not turn
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
165 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
