Question about Electrolux Refrigerators
I have a Dometic RM 7505 AES II fitted in my camper, which is now acting up. For the last two weeks it would not run on 240ac but on 12v and gas, but last night it made a lot of "clicking" sounds (like a relay not establishing itself) and the it seemed only to run on 12v. I cannot seem to be able to track down a detailed wiring diagramme so if you could suggest a likley bit to replace I would be very pleased.\r\nMany thanks, Robert
SOURCE: Dometic RM2350 Fridge not cold enough
I need motor and wiring connection
Posted on Apr 08, 2008
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 159 Answers
SOURCE: camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
Posted on May 15, 2009
SOURCE: My dometic 2652 runs is not cooling on gas or
Is there a yellow powder substance on the coils, heating tube or anywhere towards the bottom? If so, you have a leak. The best thing to do is:
1-Find a replacement unit online( ebay is a good place to start)
2-unhook electric line and gas line from the access panel
3-remove the refrigerator from the inside and place doors down(its heavy and you will probably need another person to help)
4-remove cooling unit from back of refridgerator
5-make sure you have enough thermo-mastik for the unit/coil contacts
6-replace cooling unit and hook up everything in reverse
7-turn on and let it cool for a few hours. My unit stays below 32F and works great.
Found the first one listed on ebay just now for $399.00 with a five (5) year warranty.
Posted on May 27, 2009
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
Can a dometic RF 60 absorbsion fridge be used in a camper van if gas is not connected?
google search shows that it is a 3 way fridge --12v/ mains /gas
it will operate off the battery, mains plug in ,or from a gas bottle
so --yes it will operate without a gas connection
it is not suitable for a built in application but is stand alone unit
Jan 15, 2017 | Dometic Refrigerators
Dometic RM 7505. Why isn't it working in my motorhome?
possibly it needs serviced by a repairman to add freon .
Dec 29, 2015 | Refrigerators
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Replaced control board have 115 to board can't get 12v nothing lights on frig or in side where does 12v come from voltage is good in camper Couchman with Dometic md RM2652
The 12V comes from 2 wires that come from RV and affixed to a terminal block on fridge. Insure you have 12V at those wires. Also check the fuses located inside the main electronic board. ArctiCold Refrigeration We keep it cold 28659511-ac6f-4f0b-b8c3-c7ac7cf165ac.jpg 8e5a2b6c-5f1f-429e-8512-595071232c90.jpg
Aug 29, 2013 | Dometic Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
I have a mid 70's Dometic RM 211 refrigerator in my camper. The screen on the propane burner has been damaged and needs to be replaced. Parts no longer exist from Dometic. What size wire mesh do you...
Hi Brian,
You don't want to use a screen that is made to fit. The original part was designed for a specific flame. That being said, colaws rv salvage may have a replacement burner in stock, and you can also try calling up a company that rebuilds cooling units for rv fridges.
Jun 03, 2010 | Dometic RM2193 Compact Refrigerator With...
Dometic rv refer rm2310 .. no cooling on gas /electric
THE COST OF REPAIR EXCEEDS THE VALUE OF THE UNIT
Aug 19, 2009 | Refrigerators
Rm 2611 will not run on gas when going down the road
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
Jul 28, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
457 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
