Question about Dometic Rooftop RV Air Conditioner
Unit comes on, then throws breaker
When my a/c unit comes on, after about 2 minutes, it throws a breaker. There is no other load on the any other circuit in the trailer, and the fan never blows...but i'm not sure if it is supposed to run for a short time before the blower comes on.
The unit has not been used for about 1.5 years and it is on a 2005 model travel trailer.
Thanks for any assistance you can offer!
  • 1 more comment
  • dawright Jun 01, 2008
    Thanks for the response. I'm not very familiar with these units so i'll be winging it. Is the fan motor access from underneath the unit or from the top side?
  • bwesterv Jun 10, 2008
    Hi all,
    Had the same problem, compressor would kick on, but no fan. Blew breaker after a couple of minutes.
    I toggled the system on and off about 5 different times, switching the fan from auto to 'on' every other interval. The fan finally 'released' after the 5th try. Seems like the fan was just hung up.
  • dawright Jul 19, 2008
    After removing the top cover, I manually rotated the fan, and yes, it was tight at first. After rotating manually a few times, the a/c ran perfectly! Thanks for the help!
  • 828 Answers
Fan should start at the same time as the compressor. If the fan is not running the pressure could build in the system and cause the breaker to trip. Your fan motor may need replacement, or lubricated if it is not a permanently lubricated motor bearing type. Oil ports will be located on the fan motor for front and rear bearings . There may be a dirt plug in the oil ports.
Posted on May 31, 2008
  • James Helmer
    James Helmer Jul 21, 2008
    Glad to be of assistance.
Outside ac unit breakers keeps breaking
Check all wiring for loose connections, particularly at contactor. Check for short circuit and earth leakage
Apr 21, 2012 | Heating & Cooling
The air condition in my 2006 Lardo 5th wheel keeps throwing the breaker sometime it will run 15 minutes or 4 hours then throw the breaker
You could possibly have a weak set of breakers. If you have access to an amp meter, clamp around on of the wires coming from the breakers so that you can measure the amp draw. If the amp draw of the unit (when running) is lower than the breaker rating, change the breakers.
The other problem could be a stopped up rear coil. This is the part that looks like a small radiator the the hot air blows through on the roof. You will have to take the cover off the unit to see the inside of the coil. Look through the rear fan blade and you will be able to see if the condenser coil is stopped up wit dirt etc. Hope this helps.
Aug 07, 2011 | Dometic Rooftop RV Air Conditioner
Stops after about 2 minutes and have to restart several times
Run the unit without you being on it time it and see if it runs beyond 2 minutes then get on the unit and see if it shut down. In that case its and lubrication problem. Go to or call 1-800-999-3756 and order their lube, now if after applying the the lube the the problem persists then you have a worn belt and possibly worn deck then you have to make a decision if it is worth repair Good Luck
Mar 03, 2010 | Weslo Exercise & Fitness
Heat / Cool unit runs approx 45 minutes then trips the breaker
Check the amperage of the breaker or change the breaker out completely with a new one. The tripping problem is that the breaker itself is heating up to the point that the bi-metal in the breaker (safety device) is throwing the breaker off. This could be the problem for you however, I would get an ampherage draw from the unit to insure that the breaker is the proper size for the unit. If you can find what kilowatt the unit is divide that number by the amount of current being supplied and that will give you the breaker size.
Good luck hope I helped you some
Jan 08, 2010 | Kenmore Heating & Cooling
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
Have a Ruud AC unit the problem I have after installing a new condenser fan motor when I throw the circuit breaker the unit will not turn on but when I push the contacts on the contactor in manualy the fan...
The contactor engages from low voltage power from the thermostat as does the outside condensing unit. You may have blown the low voltage transformer or have a loose thermostat wire. Check line voltage(220 volts) to the transformer. Check load voltage(24 volts) from the transformer. If no voltage out,replace the transformer. If you have voltage out(24) check the thermostat wires and the thermostat. If you have a digital thermostat there is a 5 minute delay in the thermostat after power is restored before it activates.
Oct 08, 2009 | Ruud Central System Air Conditioner
Throwing breaker
Throwing the MAIN BREAKER should not happen. Calculate the distance to your main box. Tell me the wire gauge or breaker amperage. Whatever you do, do not get a larger breaker! If its a breaker on this unit Its probably doa with current leak possibly. DO NOT USE fire hazzard IF SHE TRIPS!!! let me know if its your main breaker inthe house. Hopefully you dont have crappy cloth wiring.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Throwing Breaker
you could have a couple of reasons.If you use an extention cord that is too small,If the circut is overloaded.Bad breaker,good luck!
Jul 08, 2009 | Coleman Propane Forced Air Heater...
Whirlpool model acq158xso shuts off circuit breaker
It sounds as though the unit is dirty and during high loads, it is haveing trouble keeping up. Pull the unit from it's housing and wash it real good with a hose and sprayer. Its better to pull the unit because you can get to the coiling easier and clean it the way it needs to be clean. I bet this will solve your problem, if not then it may be low on refrigerant and the compressor is locking out and this can sometimes trip a weak breaker.
Apr 02, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Throws Breakers
Check the power cord for damage, and repair anything you find.
If confident enough, open the unit up and inspect all the internal wiring - check for chafed wires and for terminals that have come undone or that are touching anything they aren't obviously meant to.
Check the unit hasn't got wet inside - mop dry then leave to dry out properly in warm air for a couple of days if it has.
If that doesn't throw up anything obvious, then you're probably looking at insulation breakdown of some component (my money would usually be on the element). For a unit like this, I doubt it's economic to start buting spare parts, so you're probably better off buying a new coffee maker.
Good luck
Feb 23, 2008 | Bunn NHB Coffee Maker
Dometic Rooftop RV Air Conditioner Logo
211 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
