Question about Husqvarna Chain Saw 20" Bar
I have a Husqvarna model "650" chain saw which needs a new cylinder ring. It will not continue to run due to minimum compression requirements. The Husqvarna dealer says it is obsolete and cannot get the ring (one only), is there a place where I may buy rings by specification such as cylinder bore, ring depth and thickness?
  • 10,865 Answers
Hello Ron. Here is a link to several sites which claim to have this cylinder ring. Contact them. http://www.google.com/search?q=husqvarna+650+cylinder+ring&hl=en&sourceid=gd&rlz=1D1DLUS_enUS358US358
Joe
Posted on Oct 10, 2010
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a scored piston in my Husqvarna 51 chainsaw. Can I hone out the cylinder and still use it?
You can do that. But it would not run as good or as long as it would buying both the piston and the cylinder housing. You either have to buy both or the try installing a new piston with new rings in it. It should give you enough compression to start it up. But it can't be guaranteed to last too long.
May 29, 2012 | Husqvarna Chain Saw Models 51, 55
Husqvarna Model 51 won't start. Was running fine and has never had a problem starting (owned since new, 14+ years). Chain slipped off. Fixed and then saw wouldn't start. Good bright spark &...
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Sep 07, 2011 | Garden
55 rancher-put new after market piston,ring and cylinder new sparkplug,cleaned carb,tried adjusting hi lo-new gas filter,new fuel line ,cleaned air filter-will start but on acelleration bogs and dies took...
I had a very similar problem with a stihl 029 farm boss.I did everything you did except I took it to a shop to do the piston and ring replacement. When I got it back the first time it would run for about two mins. then die.I fought it for a couple of weeks then took it back and expressed my displeasure. Then checked it all over and replaced piston and ring again and it runs great. They told me they could not get the right compression with the first one and thought the groove for the ring was cut to deep.I hope this is of some help to you. Thank you.
Mar 21, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
How to take out the piston in my chain saw
The cylinder must be removed from the crankcase (be sure to clean the exterior of the engine and all parts with compressed air first). That involves removing the carburetor, muffler, cylinder head, and possibly the entire outer case parts. If the piston/ring(s) requires replacement due to scuffing, the cylinder will likely need to be replaced also. Many modern engines use a chrome plated lining for the cylinder interior and any piston damage will affect the cylinder plating also. Use great care when installing the new piston in the cylinder as the ring(s) are quite fragile. Also look for direction marks on the piston as some engines use an offset pin. Be sure to lubricate everything as you go with saw oil to prevent start-up damage. Hope this helps!
Jun 26, 2010 | Echo CS400 18" Chain Saw
Piston ring compressing
Don't use a rubber mallet! It shouldn't take that much force! Make sure the piston ring is compressed enough so it will fit inside the cylinder as you slide it down over the piston. Be very delicate! It doesn't take much effort to break a piston ring or screw up the crank bearings. Just take your time and make sure everything is lined up and extremely clean.a thin coat of 2-stroke oil on the piston, rings, and inseide the cylinder will help protect everything - just make sure you're working in a clean environment where there's no dirt and grime for the thin coat of oil to attract.
Apr 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan 18' model 2000 chain saw, quit running , will not start.
If you have a compression gauge, check the compression. Anything under 90psi is too low.
Check your flywheel key. If it is broken the flywheel will move and not fire at the correct time.
Note: if it does not sputter with carb cleaner then it's not your carb.
Next:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Mar 31, 2009 | Poulan Pro Chain Saw 46cc 20"
Compression low...what to install new rings , hone cylinder , reb
Have model and ser # available
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 25, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
140 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
