Question about Gigabyte GA880GMUD2H AM3 AMD 880G HDMI Micro ATX AMD Motherboard
Can you connect the 4pin power supply to the 8pin on board 12v
Yes, you can connect the 4 pin power supply to the 8 pin with little trouble but, you should not try any advanced features like overclocking or crossfire. If you would like to do those things I suggest getting a 4 to 8 pin adapter (very cheap usually less than $5) at most local computer stores.
Posted on Jan 30, 2011
This is my first build and all the connections are a bit confussing need picts of how to install cables to hardware
The following picture will definitely help you to install new power supply.
The 4 pin CPU power connector is using in most of the desktop motherboard. If your motherboard is gaming type or workstation board you need to connect 8pin CPU power connector. Molex connectors are using to power up DVD Drives and HDDs. In New model power supply instead of molex connector SATA Power connectors are coming.
Feb 12, 2011 | Thermaltake Toughpower XT TPX675M 675W ATX...
Motherboard will not post no video either if i have the 12v 4pin cpu plug in its socket the pc just starts and stops in a loop
The motherboard is stopping while you connecting the 12V 4pin connector because of VRM short circuit (Voltage Raiser Module, CPU V-Core circulatory). Contact Nearest Gigabyte support center for support.
Feb 12, 2011 | Gigabyte GA-EP43-DS3LR Motherboard
My new system does not work. It apears that the ATX_12V_2x connection on the board excessively loads the power supply. If this connection is removed, the power supply behaves normally, but nothing works...
hello richardwa908
you have not mentioned what model is your main board but since you said new i take it is i5-i7 series.
change the power supply. i understand it may even be new power supply but change it. specially if you are using anything over 850-900 watts power supply.
the problem is some high power power supplies cause an issue with the system. specially the ones that the 8pin connection is 4+4 type. in my case i have had to replace all my supply of 1200 watts ones with 860 watts power supplies.
hope this helps you
good luck
Jan 26, 2011 | Intel Motherboard
Board will not boot.power supply changed
The power supply and motherboard have a connection (4pin) that communicate to each other. Without this connection, the board will not boot and the power supply will not come on.
The power supply can be fooled by jumping certain pins, but the motherboard must be connected.
Please consult your motherboard manual for the location of this connector.
Visit this site for more clarification please.
http://www.pcguide.com/ref/power/sup/partsMotherboard-c.html
Sep 27, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
CPU overvolted and burn using 8pin eps12v cable on crosshair
no i dnt think so some time due to manufacturing defects this happens the new one wont burn unless and untill u over volt it.
Jan 31, 2010 | ASUS CROSSHAIR Motherboard
PC won't 4power on.
Failures in the motherboard, memory, or any installed card could cause that symptom. All I can suggest based on the above information is remove memory one piece at a time and retest, remove/reseat video card if you have one, and attempt to reset the CMOS using the jumper on the board. You might also try removing the battery on the board and unplugging everything, then attempt to reboot.
Jan 03, 2009 | Acer Aspireā„¢ T180 PC Desktop
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Power cable for A1451
yes if you will open up the unit and look on the circuit board that it connects to it is labeled plain as day what each plug is (b+, gnd..) find that out and thats how ya do it
Apr 15, 2007 | AudioBahn A1451 10-Disc CD/DVD Changer
Gigabyte GA880GMUD2H AM3 AMD 880G HDMI Micro ATX AMD Motherboard Logo
234 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
