Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
How do i open the top to access the ink ?? - Brother MFC 490cw Color Inkjet Multi-Function Printer
    Problem Solver:
  • 9 Answers
Go to this website:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=mfc490cw_all
select your language and download the Users Manual. This should tell you how access ink cartridges.
Posted on Oct 10, 2010
I installed new ink in my Compaq A1500 printer, however the printer continues to state" Clear System Err Then Press Clear." The printer is making a strange noise and it does not clear. It appears...
Try reseating the ink cartridge. Maybe, the cartridge is not seated properly.
Here are the simple steps:
1. Lift the control panel by holding the panel along the top edge.
2. Pull the control panel forward.
3. Lift the ink cartridge access door. for better access, stow the document input tray away. the carriage will move to the center.
4. Then, try reseating the cartridge. Hold the ink cartridge by the black
areas or colored top only.
Good luck,
Ryan
May 24, 2011 | Compaq Office Equipment & Supplies
How do I access the ink cartridges in my Cannon iP100?
Lift the top cover, which turns into the paper feed tray, and the front cover, which hides the output slot, drops down.
There's a second top cover, which presents the means to access the twin ink cartridges.
Open this second top cover when the printer is on, and the ink cartridges will move over allowing you to access them.
Hope this helps!
Mar 09, 2011 | Canon iP100 Portable Printer
Printer stopped printing; amber teardrop is flashing; no paper jam; cartridges should not be empty. Shouldn't there be a notice of low ink before it just stops printing? Or, the printed pages be faint? All...
The top access door on the printer might be open, or there might be something wrong with the print cartridge.
  1. Check to make sure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door opens, the print carriage moves so the yellow arrow on top of the print carriage points to a drawing of a cartridge inside the cover. Each drawing describes a symptom.
Jan 09, 2010 | HP DeskJet 5550 InkJet Printer
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do you manually position the ink unit. i.e. when an ink colour has NOTrun out when it asks for a replacemnent and on commencement of this the inks are positioned to allow top to be opened.
You can always open the top..?
The ink tray should move towards a spot where you have access to the cartridges once you open the lid.
Read the owners manual.
Aug 14, 2009 | Office Equipment & Supplies
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
Replace a ink caetridge
Open the " top access door" wait for the carriage to go to the center, pinch the latch of the inks located on lower part facing you.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do I access the ink jets?
You must open up the printer. The lift point is in the front between the paper output and glass scanning surface. You should see and indent there . When you lift it up (it does weigh a slight bit), the printer heads should move to the access position. There is a lever on top of each cartridge to unlock it front the carrage.
Oct 06, 2008 | HP PSC 750xi All-In-One InkJet Printer
Repalcing ink cartridges
Purchase the ink cartridges from a store or www.kodak.com. Open the access panel to where the ink is. Remove the old ink cartridge by pushing up on the bottom tab. Put the new ink cartridge in the slot and push down on the top tab. The ink cartridge should snap. Close the access panel and you should be good to go.
Jun 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
47 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
