Question about Toto Home
Need to replace toilet seat but cant get at bottom of bolts to tighten nuts as it is enclosed
  • 863 Answers
Use deep sockets and not a wrench. Place flat head screwdriver on the top screw for resistance, while tightening or loosening the bolt at bottom with the deep socket and wrench.
Posted on Oct 10, 2010
How do i tighten soft close toilet seat on a porcher cygnet, with no underneath access to bolts.
There is usually a plastic nut that goes on the bottom and has a wing on it that will catch when you tighten the plastic bolt from above.
Feb 19, 2015 | Porcher Home
How to install a toilet
Things needed; set of johnnie bolts, wax ring, water supply tube, open end wrenches.
insert the flat head of the johnnie bolts into the groove of the floor flange so the threads are pointed straight up. Install the wax ring directly onto the floor flange. Set your toilet bowl down on top of the wax ring so the johnnie bolts stick up through the holes at the bottom. Install the washers and nut to secure the toilet to the floor. Depending on the type of toilet, you may or may not need to manually install the tank to bowl gasket and tank to bowl bolts. Set tank onto bowl and tighten the bolts. Usually a 1/2" wrench. Do not over tighten because the porcelain will break. Install the water supply to the bottom of the tank and then tighten it to the water shutoff valve. Install the seat, and your all set.
Apr 09, 2014 | VitrA Home
Kohler cimarron broken seat, replacement parts don't work 2x's
No do not use metal bolt and nut as this can crack the toilet. Just go to Lowes or Home Depot and buy 2 plastic bolts , 2 plastic wing nuts, and 2 plastic washers. Install with seat through toilet holes and tighten by hand until tight. I then use pliers to tight just a turn tighter and the seat should be center as you tightened one side, then the other, and back again until tight.
Mar 17, 2013 | Kohler Cimarron Comfort Height 2-Piece 1.6...
One side of the toilet seat has come loose and can be partially lifted
It'll take getting down on your hands and knees in front of a toilet, but oh well. :-) Look beneath the side that is loose. There will be a threaded plastic bolt coming down from the top of the toilet to below where you are looking. On this threaded bolt there is a nut that needs to be tightened. Reach up and tighten it as tight as you can with your fingers. To make it even tighter, use a pair of pliers... then just snug it firmly. For ease in getting it off another time (e.g. should you want to replace the seat cover), I suggest first taking the nut OFF. Then take plumbers silicone tape (found in the plumbing section at any hardware store; it looks like white thin, thin tape) and wrap the bolt with it. Note: you need to take pull the bolt out completely to do this. After wrapping it with silicone tape, insert it back into the hole, and then twist the nut back on; snugging-up with a pair of pliers. This will keep the nut from working itself off, and will make the nut come off easy should you ever desire. Good luck.... :-)
Feb 27, 2011 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
I have a Toto toilet and am trying to replace the old seat. BUT the bottom is a solid piece and makes it impossible to access the seat bolt for tightening. I began loosening the seat bolts. now I have a...
hi there
this type of seat has rubber gromits that squeeze up when you tighten the screw.if it wont tighten up the gromit may have failed and would need to be replaced.
good luck
Dec 18, 2010 | Toto Carrollton Toilet Tank - ST774S-01 -...
The toilet seat is very loose and I can't figure out how to tighten it. Please help! Its about to come off completely Thanks
Usually there are plastic caps that snap down over the bolt head.
Shut toilet lid and get down close with a flashlight.
Seat attaches in two places.
Reach underneath and you can feel two bolts with nuts.
You don't need to see them, just feel with your hand.
The bolt head is covered with a plastic cover.
The cover is added for aesthetic purpose only.
Use small screwdriver or fingernail file or nail or scissors to pry up the cover and reveal bolt head.
Use bigger screwdriver to tighten bolts.
You may have to keep one hand on underside to hold nut while turning bolt clockwise.
Another trick is use hand to push bolt all the way up, and then finger tighten bolt most of the way, and use screwdriver for last few turns.
Tighten bolts good and tight, but don't overdo it.
Bolts will come loose again and you can tighten more later.
Dec 13, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
How to stop seat from wobbling doesnt seem to have screws that fo into seat just a place for seat to sit on and then some cap to put over but nothing seems to tighten it.Im tired of falling off the toilet
First lift the covers off where the bolts should be (they should lift towards the tank). Are the bolts in place? If not, go to your neighborhood hardware store and look for replacement hardware. (Most stores will have staff willing to help you find the right parts.) Is the bowl damaged so that the holes seem large compared to the holes in the seat anchor points? Are the seat anchor points damaged?
The bolts should have nuts (and possibly washers, but not all models use them) underneath the bowl. Screw down the bolt while holding the nut from turning (so you need an adjustable wrench or appropriately sized wrench). Again see the local hardware store for the hardware if you do not have the nuts. Keep the seat centered as you tighten the bolts. (Alternate tightening until it is stable - do not tighten one bolt all the way down before doing the other side. You risk overtightening and cracking the bowl.)
I hope this helps.
(if the seat is damaged, you may want to replace it. If the bowl is damaged you must replace that.)
Jun 10, 2010 | Kohler - Toilet Seat - Moondance -...
How do you tighten bolts on Kohler toilet seats the bolt has a plastic cap?
The caps are at the back of the toilet seat. Just under the cap cover are the bolts. You will need a meduim sized flat screw driver. Hold the nut on the bottom and use the screw driver to tighten.
The covers pry up with a small screw driver IF they are square.
If they are more circular with ears they rotate counter clockwise about 30 degrees, Then lift the lid off.
Please rate this response and Good Luck, Phil
Dec 29, 2008 | Home
Home Logo
306 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
