Computer starts but can't get it to boot up - Computers & Internet
  • 340 Answers
If you can get to the Dell logo hit the f8 key a few times when you see that screen. This will take you to the windows repair screen. Its a black screen with multiple options, arrow down to the option that says restore to last known good configuration and hit enter. You will get a screen with some dates on it, choose the date that you know your computer was working fine, hit enter and the computer will reboot and if all goes well, you should get into windows. Hope this helps
Posted on Oct 10, 2010
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
When I restart with the boot disk I made (or the intstallation disk) the computer starts up normally. I am not being prompted to scrub it. Help!
you need to change the boot order of the computer to boot from cd instead of hard drive.
When you first start up the computer you should see a message to press to enter setup the most common keys are:
  • Delete
  • F1
  • F2
  • F3
  • F5
  • F10
  • Escape
  • Insert
  • Control + Escape
  • Alt + Escape
  • Control + Alt + Escape
  • Control + Alt + Enter
Once you've entered setup you should be able to find a selection something to the effect of boot order chage the fist boot selection or primary boot device to the CD rom so that the computer will boot from the boot disk instead of the hard drive
Apr 19, 2011 | Iolo Technologies DriveScrubber
Cannot get computer started. Keeps asking for Boot media device
There are quite a few possibilities over here.
  1. the boot device might have got changed from harddisk to some other.
  2. the boot sector of the computer might have gone bad and needs repair.
Solution for the first one:
Try getting into the boot sector of the computer and change the boot order to Harddisk as first boot device and then CD ROM and then Floppy drive (if you have)
Solution for second one:
If its a Vista/Win7, then try starting the computer into the advanced boot menu.. then select Startup Repair.
Feb 13, 2011 | ASUS Essentio Desktop with Intel Core 2...
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
Oxcoooooof
pauljohnchef.
If you want the computer to boot from the CD, you need to tell the computer to boot from the CD. At start up the computer runs through each device one at a time and tries to boot from it and it will boot from the first device that has a boot log. Right now your computer is set to boot from the hard drive before the CD drive.
Always back up your computer before going into the systems bios menu.
After a backup, upon starting the computer, press F12 when the bios selection appears shortly before the operating systems starts. Once in your bios menu, go to the boot order and tell your computer to first boot from the CD then your hard drive; then your disk drive if you have one.
After you are done, you can go back into the bios menu and change it back to booting from the hard drive first.
-Chris
Feb 28, 2010 | Toshiba Satellite P205-S6287 Notebook PC
Haw to boot dvd windows in my laptop hp hdx16
Dear user,
Please set the CD/DVD ROM as a first boot device in bios setup. then you will be able to boot from CD/DVD.
Please dont forget to RATE my answer
Sep 05, 2009 | HP HDX16t Entertainment Notebook PC
Acer Aspire one will not start. I get a error while initializing the NIC, No bootable device-- insert boot disk and press any key...There is no boot disk.. Any suggestions please..
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Aug 06, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
David Payne
David Payne
