Question about LG 42PX5D 42 in. Plasma HDTV
No power well my TV was fine then the next moment i plugged it in, it wont start or open or something....HELP?! :D
  • Anonymous Jul 09, 2008
    The green light stays on but I have no picture or sound for 1 week now. I left it unplugged hoping it will start..still no luck. It's as if its in a stuck mode(Sanyo Model DP42746) help please
  • rondee2 Sep 17, 2008
    i took tv down for shipment .when i plugged it in nothing happens. no light, no power.
    ron
    Genius:
  • 1,074 Answers
You are having problem in the power supply of your tv or your micro chip is bad which also controls the power on for your tv have a tech repair your tv.good luck.
Posted on Jul 25, 2008
So my tv has worked fine for about a year or so and then it stopped working, wont turn on so i left it alone and unplugged for awhile thinking i needed to get a new oe then a couple weeks has passed and i...
It most certainly a power supply issue. If the board is separate you might find one reasonable, but some are all-in-one boards and only a technician who knows how to repair the electronics will help you. most of these are bad capcitors
Oct 17, 2013 | Sanyo DP50747 50 in. Plasma TV
My RCA HDTV wont turn on can u help
HI Kenya - Have you checked to make sure that the outlet your TV is plugged into has power? If not, unplug your TV and plug something else in to see. If there is no power, then you have an issue with your circuit/breaker box. Have you tried your remote control (will charged batteries) and tried turning it on manually from the front of the TV? If you've tried all of these things and they are fine, then it is something internally wrong with your TV. Unless you are willing to take it apart and figure out, you will need to take it for repair or replace it. I am sorry, but there is no simple solution without knowing more detail about it.
Nov 30, 2012 | Televison & Video
Have a sony Bravia 32L4000 that wont turn on
seems to be fine? replace the main power board
Jul 23, 2017 | Sony KDL32L4000 32 in. LCD HDTV
Holds idle fine but stalls when accelerating
your carburetor should have a fuel filter in the carburetor body where the
fuel line enters it replace it and, any other in-line fuel filter the engine might have
Jul 25, 2010 | 1986 Jeep Cherokee
Peugeot partner wont start first thing once
i presume its a diesel
i reckon its the glow plugs get them checked i am sure a new set will cure your problem
Nov 05, 2009 | 2006 Peugeot 604
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
No picture on Packard Bell LCD TV 170ASW
Hi there , dont no if this is any help , i have the same model that would display an image when its in setup mode but as soon as you choose tv or computer it would go blank with just sound , did not find the exact fault there s a small short to do with the backlight board , but when i remove the backlight connector from the main pcb and remove the yellow ? wire from the connector the one on the xtal side of the connector and refitted the connector with out the yellow wire the tv worked fine .
Dec 26, 2008 | Televison & Video
I cant plug in my ps2 to my tv!!
Soi didnt exactly fix this but basically i figured out that the ps2 is simply too old for that new tv. when i plugged in a newer system it worked just fine so i guess ill just have to deal.
Dec 13, 2008 | Panasonic PT-43LC14 43" Rear Projection...
LG 42PX5D 42 in. Plasma HDTV Logo
54 people viewed this question
Computer Repairing
Computer Repairing
