Question about Consew 226R-1
I am not sure if I have a 226R-1 or R-2, my machine just says 226. I broke a needle and since then my machine skips stitches. Please advise how to fix. It only skips on vinyl, not cloth.
  • Consew Master
  • 12,029 Answers
Could be the incorrect needle for the machine. Also, vinyl is difficult to sew because its "stickiness" characteristic tends to grab and hold the thread during the stitching process and is more likely to cause skipped stitches. Look for a needle with a large groove to shield the thread from the fabric--perhaps a topstitch needle or even a leather needle.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjHsbHCp9LMAhVDw4MKHUhpCiEQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
All About Needles
Tips and Techniques for Sewing with Oil Cloth Vinyl Laminated Cotton
Posted on May 11, 2016
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Indsew.com here. I would also recommend to check and replace if needed rotating hook. When needle brakes it usually hits something inside and rotating hook is right there and it is the part that is responsible for catching your thread for each stitch. If your needle have hit the blade of rotating hook the chances are they have bent. It is hardened steel and can not be unbend - it will break, so the whole rotating hook is usually gets replaced. When you replace it you will need unscrew and take off the shaft the old one and before tightening the new one to align it so the sharp point of the hook blade will be next to the needle eye at the lowest needle position - this will synchronize it.
Posted on May 10, 2016
  • 48 Answers
My first question would be, Did you replace the needle with one the same length as the one you broke? Second: Is it a new needle? If you answered no to either of these questions this could be the cause. Your needle should be size 135x17.Size 23 for a thicker needle, size 20 for a thinner needle. If replacing the current needle doesn't cure the problem. Then it's a timing issue. Try dropping the needle down a little bit and retighten it. This is a simple timing fix that will do one of two things. 1) Make the problem go away. 2) Make the problem worse.If it makes the problem worse then adjust your timing.
Posted on Jan 05, 2011
Slant o matic 401g skipping stitches what is wrong
Make sure you are using a brand new needle. A damaged needle will frequently cause skipped stitches. (Changing the needle is the least expensive repair for machine problems!!!!)
There is a lot of information available on the internet.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Nov 17, 2016 | Sewing Machines
My pfaff hobbymatic 875 is skipping thread on the bobbin side
Be sure to use a brand new needle. If the needle is bent or damaged, it will frequently skip stitches. Also, if you are using the incorrect needle for the fabric & thread you are using, it will skip stitches, ie a ball point needle on woven fabric.
All About Needles
Oct 21, 2016 | PfaFF Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
Here What to Do if Your Sewing Machine is Skipping Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
I have a consew machine 226 and the needle thread will not pick up the bobbin thread .
your needle is in backward, the groove must point to the left.
Dec 30, 2009 | Consew 226R-1
In need to know how to adjust my stiching and needle adjustment/ the bobing is jamming(not stiching)
Stitch length is adjusted by holding down the small button in the bed and turning the wheel to the desired number of stitches. The numbers are either on the wheel, next to the belt pulley, or under a small cover on top of the machine. Hold the button and turn the wheel either toward or away from you to get the stitches you want.
Bobbin jamming is either because of incorrect top tension or incorrect threading. Go to www.consew.com and get a parts and operation manual for free for a 224. It 's the same as the 226.
Mar 10, 2009 | Consew 226R-1
Consew 226 breaking needles
I posted an answer to this a couple days ago. If the hook's hitting the needle you need to move it away from the needle. There's a small screw in the bottom of the machine that holds the hook mechanism in place. You need to loosen the screw and gently tap the assembly away from the needle. The hook should just pick up the looped thread as the needle bar rises. You can go to www.consew.com and download a pdf file showing the parts of the machine, also an owners manual. You have to click on the 224 machine. The manual's the same for 224, 225, 226. Or you can click on the 226R-3 - that's the same, too.
Sep 26, 2008 | Consew 226R-1
Consew 226R-2
You can download a free PDF file from www.consew.com. There's a complete parts list but you have to click on the 224 to get the 226 manual. It's free - 10 pages!
Aug 31, 2007 | Consew 226R-1
Consew 226R-1 Logo
207 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
