Question about American DJ Fogstorm 1700hd Fog Machine W/ Remote System
The low juic sensor stays on even when the tank is full
    Problem Solver:
  • 13 Answers
Replace the sensor by opening the unit. The sensor seat itself might not be sat properly.
Posted on Nov 06, 2013
Low fuel light on honda civic ex 2012 stays on with full tank of fuel
The tank sensor is faulty. If you still know how much is in the tank with the gauge, then it's usually the limit switch which is part of the tank sensor..
Apr 17, 2017 | Honda Civic Cars & Trucks
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Warning light for low fuel stays on
The sensor is part of the fuel pump module inside the gas tank.
The signal is sent to the body computer, so it could be a faulty module or a problem with the body computer.
The circuit would need to be checked with a meter.
Feb 08, 2013 | Volkswagen Cars & Trucks
Fuel gauge not working
Sounds like the float is stuck, or corroded. Look to see if you have an access door above the fuel tank. If so you should be able to take out the fuel sender, unstick the float, or clean the sensor, and replace it
Feb 10, 2012 | 1999 Nissan Quest
Low washer fluid light stays on
Either the resivoir is low of fluid or the sensor is stuck down or defective. Inspect the fluid level sensor.
Jan 03, 2011 | 2005 Chevrolet Malibu
The low fuel light stays on even when tank is
Hi: Your Fuel Level Sending Unit That Is Located in Your Fuel Tank Is Probally Bad. BUT before you go to taking the Sending Unit out Of your Tank Check to see if ALL Connections To And From Tank to Gauge are Conected Good. Also You could have a Fuse that Goes to the Sending Unit,in Your Fuse Block.Check And See if You Have A Fuse Labeled Fuel Sending Unit or Fuel Sensor. If you end up Replacing The Fuel Tank Sending Unit Run Your Gas Tank Down To Almost Out Of Gas Before You Start to Remove The Metal Straps Holding Your Tank Up. Cause The Sending Unit Is on Top of Your Tank ,And Your Fuel Pump Is In The Gas Tank As Well. Hope This Has Helped You Please Send Me a Vote on How my Solutions Have Helped You And Also You Can Send Me A Testamony Thank You From the WYOCWBOY
May 31, 2010 | 2005 Chevrolet Impala
2002 eldorado ESC- gas gauges stays on full
Not a fuse.There is no fuse for the level sensor.These are known for fuel level sensors being bad.Sometimes they will leave a code and sometimes not.You can check codes and see if you have a fuel level sensor code.The other thing you can do is check the connections and make sure they are clean and on securely.If you find that the level sensor is bad.Then it is easier to replace if the fuel in the tank is as low as possible for easier removal of the fuel tank.Hope this helps.Good luck.
Dec 21, 2009 | 2000 Cadillac Eldorado
Low coolant light stays on, coolant level is full
Check coolant level sensor, sit in the coolant resv. tank has two wire that go to it, tap on tank see if light goes off, if it don't replace sensor easy to do, part run's about $12.00 - $20.00, part # FLS609 at NAPA. Hope this was helpful.
Dec 11, 2009 | 1996 Chevrolet Cavalier
Low coolant light staying on
if the coolant is full you need to check and most likly change the low level sensor in the coolant tank.
Jun 11, 2009 | 2000 Ford Taurus
American DJ Fogstorm 1700hd Fog Machine W/ Remote System Logo
47 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
