Question about Home
The shower turns on and makes all the noises but no water
  • 863 Answers
Clogged pipes or turn the water shut off valve to on position.
Posted on Oct 11, 2010
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
After changing my Delta shower cartridge i hear a whining noise when i run hot water in the shower. If I also turn on hot water in the bathroom sink (at same time) I get a banging noise from the pipes. ...
the banging noise is called water hammer and there are devices that can be added to your water lines to absorb the shock.
As for the noise, when you had the old cart out, did you flush out the faucet by turning in the water for a few seconds after removing the old one? This is a four hand job, one to control the water gushing out of the faucet and the other to conrol the shutoffs.
check seat and spring for correct assembly, the whine is caused by water pressure and flow obstruction.
Jun 20, 2013 | Home
Triton shower noise in motor
May have calcium buildup in the system from hard water. See if you can get lime away inside the units passages for a short soak then lube it with a silicone based lubricant or vasline.
Sep 23, 2009 | Home
SHower noise
Loose washer in hot or cold tap. Replace or tighten.
Sep 10, 2009 | Water Pik Shower Head
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
Mar 26, 2009 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Home Logo
63 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
