Question about Optoma RD65 65" Rear Projection HDTV
The lamp light comes on when tv is turned on and tv turns itself off....i assume it's telling me the lamp needs replacement but could it mean something else....thanks
    Problem Solver:
  • 5 Answers
WOULD YOU BE INTERESTED IN SELLING YOUR RD65 TO ME FOR PARTS ? PLEASE CALL WALT @ 313 220-5440 THANKS
Posted on Oct 26, 2011
Tv starts to turn on then red light comes on and tv turns off
The red light indicates the lamp has has failed to light. You might just need a new lamp. If replacing the lamp does not solve your problem then the capacitors on PWB-Power need to be replaced or the lamp ballast itself has gone bad.
Dec 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My tv turned itself off and not even the stand by light was on. i unplugged it and changed the lamp. when i plugged it back in the stand by light came on but the tv doesnt. under the stand by light is a...
when you turn TV on, watch to see if the Lamp Fan is running,if it stops when Lamp trys to light then set will not come on.which then means Lamp Fan is defective.
Nov 24, 2010 | LG RU-52SZ51D 52" Rear Projection...
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV TURNS ITSELF OFF AND AFTER A FEW MINUTES WILL COME BACK ON. IS THIS A TV PROBLEM OR A CABLE PROBLEM
I assume this is an LCD or SxRD projection TV... you need a lamp. The lamp's burner is worn from use and when it becomes hot, expansion occurs and the lamp extinguishes. The TV will attempt to reignite the lamp 3 times after it goes out. If successful, it will continue to operate until the burner expanded too far once again. This will repeat over and over. Eventually, the lamp will not come back on. Order a lamp and replace it. Best wishes, I hope this was helpful.
Jul 13, 2010 | Sony Televison & Video
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
My lamp light is blinking, what does that mean
that lamp light is telling you that your lamp was at the end of its life span and it sounds like the bulb has failed
you would have to order a lamp and replace it to restore pic
although model and brand would have been nice
but this is the problem with most DLP sets
the lamp is estimated to last 5000 to 7000 hrs
Jan 21, 2009 | Televison & Video
Tv turns off and on
The first time my lamp needed replaced, the red light came on as well. This time my tv did the same thing, but after talking to my tv repair man he thought it was the lamp. He said that if you use your tv often then the lamp probaly needs to be changed after two or three years. I replacedmy bulb and it corrected the problem and I MUCH BETTER PICTURE.
Dec 29, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
My tv turns off
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HL-R6167W 61" HDTV
Optoma RD65 65" Rear Projection HDTV Logo
49 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
