Question about Cannon Safe S6030BLUE Safari Serengeti Series 22 Gun Safe Pacific Blue
I have a cannon safe and the opening mechanism is jammed. I can hear the lock release but the handle won't turn to release the locking bar. Cannon model AE22 with an electronic key pad
SOURCE: cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Posted on Jan 05, 2008
vegakitten20
  • 685 Answers
SOURCE: JUST DELIVERED OUR NEW CANNON
if i were u i would send it back cause you will have nothing but problems
Posted on Nov 11, 2008
yboyandrei
  • 828 Answers
SOURCE: I want to clean my cannon ip1000 ink pads
Open your printer. Locate Waste Ink Pad inside in your Printer, on the right hand side are quite small.
You can remove the pads & holder with a gentle pull.
Using a tissue, soak as much as ink as possible and clean around the waste ink area.
Be careful & Patient.
Whilst the printer is disconnected from the main power. Press and hold the Power Button and reconnect to AC Power.
Release the Power Button & Press the Power Button Again.
If i am helpful to you, please rate me.
Thank you.
Posted on Aug 31, 2009
mikesreel
  • 76 Answers
SOURCE: Cannon Digitrol 1V bottom tracking not working
Hello!
Here is the user manual for your downrigger:
DT IV Downrigger
The programming starts on page 12.
Best of luck!
Mike
Posted on Sep 27, 2009
LongPockets
  • 1177 Answers
SOURCE: hi When I try to
Your memory card is an SD type. These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Posted on Nov 04, 2010
My cannon safary safe wont open, the code is right but the handle just keeps on turning all around and wont let me open it. any ideas of how to open it.
You said the handle turns but doesn't open. This might be because the handle has unlatched from the bolting mechanism or has jammed. If your safe has batteries, replace them, and it's also possible the wiring has broken. Try giving it a few taps with a hammer, but if this doesn't work you may need to contact a technitian
Nov 04, 2016 | Home Security
New cannon gun safe will not lock
Check you users guide. Ask who you got your new safe from.
Nov 26, 2015 | Locks & Locksmithing
My cannon safe with a s&g lock will ot open
[PDF]Cannon Safe Owner's Manual
https://www.cannonsafe.com/media/manual.../CannonOwnersManual.pdf
*EMP Lock is not available to retrofit on other safes; not sold separately. Page 9. Page '. 7. NL Lock. Programing the lock. Step 1. Open the safe door (factory code is ... Low Battery Warning: The lock will repeatedly beep during unlocking.
Opening a Cannon Safe with S&G lock set on factory combo ...
? 0:41
https://www.youtube.com/watch?v=XlYxrWhSLwE
Nov 6, 2008 - Uploaded by gunsafeman
opening a Cannon Safe with combo of 1,2,3,4,5,6 #
Nov 07, 2015 | Locks & Locksmithing
New batteries installed. Key pad indicates unlocked, but will not open
sounds like your lock mechanism is jamming if safe excepts code then it is not the code.You might wanna try a thin butter knife in between the top and bottom maybe you can slide the lock mechanism over dont force it for the lock bars arent that strong.try pressing down on the top sometimes it doesnt release properly. another option is to hit the top of it with a rubber mallet sometimes this will release the lock.
Mar 06, 2015 | Sentry Fireproof Safe
Toyota door lock
Hi John, If the latching mechanism is in the locked position, does it open when either of the handles are pulled? If it is not opening you may need clean and service the linkages and the latching mechanism or replace the latch. The locking mechanism inside the latch is is an off center sort of horse shoe shape. If it is closed you will see a bar which will be in an almost vertical position, and it should release when either of the door handles is operated. If it is failing to lock, (which I am suspecting), the latch will be at an angle of about fifty degrees. If that is the case, using a Philips (star screw driver) push the latch back to find out if it is latching. If it does, use either of the handles to release it again. If it fails to hold in the closed position, the linkages from the release handles may be fouled, damaged or disconnected. If everything is correct in those areas, the latch may need replacement. Check that first, let me know how you get on and if we need to go further and carry out a replacement, which will mean removing the door panel, and the mechanism let me know so we can go through it together. Regards John
Jan 18, 2013 | 2000 Toyota Avalon
Liftgate on 2005 uplander won't open
The locking mechanism on the rear lift gate for the Chevy Uplander has some plastic and rubber-coated parts that can get jammed. If you can pull back the panel from the inside top near the glass, you can reach down and try to spray some silicone lubricant into the lock. This could help get those parts unstuck so they spring back when you pull on the handle latch from the outside. Once you get the rear hatch open, I recommend taking out the locking mechanism and thoroughly lubricating it. Your rear lift gate will start to release very easily from then on.
Apr 08, 2012 | 2005 Chevrolet Uplander
I need a diagram of the locking mechanism in my 2001 nissan sentra so that i can use a slim jim to unlock the passenger side door.
I don't have a diagram of the door but if you slip the slim Jim in over the top of the outside door handle it should catch on the latch bar. If you are doing this because the door won't open from the interior handle or the outside handle the problem most likely isn't the lock. The way that handle connects to the release it is held in place with a piece of plastic that breaks fairly easy. If that piece breaks the interior door handle won't activate the unlock function when pulled and you will have a heck of a time getting the door opened so you can get inside the panel to do the repair.
Oct 05, 2011 | 2001 Nissan Sentra
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
Cannon Safe S6030BLUE Safari Serengeti Series 22 Gun Safe  Pacific Blue Logo
579 people viewed this question
Top Cannon Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Cannon Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
