Question about Philips Televison & Video
My philips model 42pfl5432d/37 will not turn on or go into standby mode. It has happened once before and unplugging it and plugging it back in did the trick, but not this time.
  • 133 Answers
SOURCE: Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
Posted on Aug 10, 2009
dsacco86
  • 1077 Answers
SOURCE: Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Posted on Aug 12, 2009
phil_frye
  • 295 Answers
SOURCE: My 42PF5321D/37 will not turn on, just flashes a
Most likely a power supply problem. If it's covered under the warranty take it in right away and have them fix it. If not a good Philip's service shop can fix it. They may have a flat fee repair charge?
Blessings,
A/V Guy
Posted on Nov 19, 2009
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
I have a Philips 42PFL5432D/37 and everytime I turn it on it goes back off in about 5 seconds
Measure some voltages on the power board and see if some are dropping off when it shuts down, if they are chances are you have a bad power board
Jan 26, 2018 | Philips Televison & Video
How can i fix my Philips model 42PFL5432D/37 Flat screen TV that powers on, but no picture.
The main board to your TV is faulty. It is best to contact the authorized service center for Philips; because, it will be very difficult to get the main board to Philips brand TVs, and after the replacement, a firmware update too will be necessary. This is a skilled work. http://electronicshelponline.blogspot.com/
Jul 27, 2015 | Philips Televison & Video
Philips 42pfl5432d 37
Could be power supply failure
Apr 14, 2014 | Televison & Video
Philips 42pfl5432d/37 tv chirps when power is on
Usually stems from a short on the power supply board. I have a 37MF337B/37 37" that had the same problem. Turned out the set had 5 leaky capacitors and a shorted diode on the power supply board.
Jan 10, 2013 | Philips Televison & Video
Model #42PFL5432D/37 Not receiving power? when
i was a tv engineer for many years quite a while back now and when a led is flasing or pulsing it usualy means the tv's power supply is in over current mode wherebye it shuts down to prevent any further damage due to a part of the circuitry drawing excess current, high voltage transformer etc, you need to get a techie in, sorry.
Nov 03, 2010 | Philips Televison & Video
I have a Philips Model 42pfl5432d with a picture
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Dec 18, 2009 | Televison & Video
based on what you clarified and my experience I'd bet the problem is in one of the inverters, most likely the main inverter.
Look at the board part number - it's usually imprinted on the board itself - and look on eBay or Google for it.
Another way to go about it is to type in the model number (usually without /37) followed by the word "inverter", e.g. "42pfl5432d inverter".
My search yielded result board number VIT70023.80 and from there you start searching for this on eBay...find a reputable seller (like me, except I don't think I have it) and buy it.
It might be the slave inverter, it might be the master, but from what you describe it's more likely the master.
It's possible to nail it down, but it will require multimeter and some extra time.
Hope that helps!
Nov 15, 2009 | Philips Televison & Video
42PFL5432D - No Sound
I don't have a copy of one to help or walk you through it.. But this site does have one for download. $9.99
http://www.user-manuals.com/advanced_search_result.php?keywords=42pfl5432d/37+manual&forward=plist
Sorry I can't help you out more.
May 24, 2009 | Philips Televison & Video
Jan 10, 2009 | Philips 42PF9431D/37 TV
Televison & Video Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
