Question about Whirlpool Refrigerators
BAD SMELL COMING FROM THE UNDERNEATH OF MY SIDE BY SIDE WHIRLPOOL FRIDGE. SMELLS LIKE URINE....
  • 828 Answers
There is a drain collection pan under the left side behind the toe plate. Remove the drain tray and clean it.
Posted on May 31, 2008
Cadet 3 toilet smells like pee - NOT a SEWER smell, a urine smell. It's a brand new toilet, installed by our contractor. There's a brand new extra thick wax ring too. The room smells like urine when nobody...
If your contractor supplied the toilet, then it is his/her problem, not yours. If you supplied the toilet, then: take a mirror and examine under the lip of the bowl. How does the glazing look? Are there areas without glaze? If so, these bare areas are a breeding ground for bad odors. You can try a thorough cleaning both inside the bowl and around the outside of the toilet with an amonia cleaning product. If you use amonia, DO NOT use bleach: the two combined create a deadly gas. Whatever you do, do not hang a bleach based product inside the tank: the bleach will eat away at anything rubber inside the tank. There is a bleach product that hangs inside the tank and disperses the bleach directly into the tube that leads to the toilet bowl. This would be OK.
Aug 12, 2013 | American Standard 4021 White Cadet 3...
My fridge smells bad. We have removed everything and cleaned it out and the smell went away for a a while but it is back. What else can we do to get rid of the smell. It is worse when you open the...
yes u can try new newspaper crumpled up all in the ref. and freezer.. it will absorb the smell. but make sure to wipe it again with clorox or bleach water. also charocal u know bar-b-q char. left inside will absorb a lot of smells. ok try that.
Feb 13, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
My whirlpool fridge gold series has a urine smell coming from it when it runs...from the back
Well if you have pets that maybe your answer.Freon is tastleess and has no sent.Also cheak if there is alot of lint bult up ander it.
Sep 22, 2010 | Whirlpool GD2SHGX Refrigerator
Hello i am having a foul smell coming from underneath the refrigerator. it doesn't have the drip pan on it..i removed it due to a previous foul smell..are these refrigerators known to have this type of...
the smell is bacteria caused by condensation from the drain pipe/drip pan,syringe with chlorine bleach, all fridges will smell if not looked after in the proper manner....but how many of us read the book......(if you removed the drip pan then you have the bacteria all over your floor.....will discolour/ruin any surface/carpet...
Jul 30, 2010 | Admiral Refrigerators
Fridge blows horrible smell
poss drain holes blocked,use a syringe to blow through with clorine bleach.(clorine will gas off so no after smells)
Jun 08, 2010 | Whirlpool GD2SHGX Refrigerator
My refrigerator is one year old. There is a bad
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Jan 06, 2010 | Whirlpool Refrigerators
Odor coming from back of fridge
This is very unusual, most of the time when I get complaints about odor it's form the inside of the cabinet. This should be easy enough to solve though. The odor is likely from dust accumulated underneath, or from something in the drain pan. If the unit has visible fiberglass insulation underneath you should replace it with new because, even if the source of the odor has been removed, the insulation can still contain it.
Unplug the refrigerator, take off the kick plate and rear cover. Clean and vacuum the entire under- carriage, condenser, fan, and condensation evaporator tray.
Be gentle with the components though, especially the capillary tube ( a pipe about the size of a 14 gauge copper wire )
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
My refrigerator smells like urine
The smell is coming from the back of my refrigerator and it has been noticeable for about a month. It is the worst when the motor is running. The inside is fine; no smell. Any ideas?
Jun 06, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
BAD SMELL COMING FROM UNDER MY WHIRLPOOL SIDE BY SIDE FRIDGE. I SMELL IT WHEN THE FAN BLOWS. IT SMELLS LIKE URINE.
check its not the drained ice water which collects on a pan over the compressor. the compressor heat is supposed to evaporate it .that foul smell might be due to that.
if that is the case ,switch off fridge , clean , dry , the pan & see .
May 31, 2008 | Whirlpool Refrigerators
Refrigerators Logo
323 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
