Question about Nikon COOLPIX S230 Digital Camera
Lens Error: Camera can't focus - Nikon COOLPIX S230 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 10, 2010
How to fix err 01
you have a faulty connection between the lens and body of the camera
  • remove the lens clean contacts on lens and the body of the camera
  • remount the lens
  • if you still encounter the error turn off the auto focus switch .
  • take a test shot (manual focus)
  • if you did not encounter the error your lens might have a faulty flex cable have it checked / replaced at the service center
Aug 24, 2014 | Canon EF 50mm f/1.8 II Lens
Fuji film finepixF480 showing focus error
Possible that the lens mechanism is jammed , sometimes the flexible connector of the lens focus/zoom can be faulty.You try to check for some tips from the link below; http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 30, 2011 | Fuji FinePix F480 Digital Camera
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
Lens error and out of focus images
HI there the camera lens guide pin is damages and thats why not focusing the image properly . that's why you got the lens error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Casio Exilim EXZ75 Digital Camera
I had the E18 error--lens wouldn't retract and
Focus problems are quite common after a lens error, it sounds like you still have an issue with that lens unit. If you need help, there's a great site taht just specializes in the powershot problems, nothing else at all. Try going to www.camerasandparts.com and you'll see the fix for this for your SD890 camera. I hope that helps, that site is amazing for the powershots and that's where a lot of people go for help with these. Good luck with it.
Feb 21, 2010 | Canon PowerShot SD890 IS Digital Camera
Lens error please help!!!
If the sand is in the zoom gears or auto focus gears then the camera would need to be disassembled to remove. Nice thing about this camera is that no soldering is required to take apart. A few small screwdrivers, and some tweezers would be all that is required. Canned air and a needle might also be helpful for removing the sand. If the camera just buzzes then I would say that the sand is in the auto focus gears (the stepper motor will buzz). If the auto focus lens is not fully retracted then the camera lens will not go back in (to prevent the auto focus lens from bumping against the shutter assembly)
May 11, 2009 | Canon PowerShot SD1000 Digital Camera
Nikon Coolpix: lens goes in and out of focus, then LENS ERROR
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 10, 2009 | Nikon COOLPIX L18 Digital Camera
Hi there i have a auto focus problem. i used mt 50D for the first time on saturday, after about 100 shots Err99 appeared, i turned the camera off and took the battery out an the error message never occured...
The camera is having problems with your lens and this is why it goues into the error mode. Try first cleaning the interface contacts on the lens ( see enclosed pic ) . If this does not sort the problem out then the auto focus motor ( or related hardware ) inside the lens will need attention. Also try other lenses to see whether it is only the lens ( I very seldom see this sort of problem cause by the body ; it is always the lens that gives this sort of trouble )db49ae2.jpg
Nov 04, 2008 | Canon Cameras
My new Canon SX100IS is having "Lens error, Restart Camera" error
It seems the lens assembly has an internal problem and needs to be repaired.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
The reason of it it may be a spring or a metal post located in the focus sub-assembly, but the only way to confirm it is opening the camera and the lens assembly.
Best regards,
Jul 25, 2008 | Canon IXUS V2 Digital Camera
Lens error
The most common cause of this issue on the L3 is an impact which dislodges the focus element in the very front of the lens. The metal platform that the focus system is mounted to is attached with 1 screw and is able to flex slightly under stress. When impacted it flexes and allows the focus drive to become misaligned. The lens still technically works but the camera senses that the focus is jammed and leaves the lens extended so no components will be damaged by retracting. This repair costs $145 at my shop, not an economical repair for this camera. Some parts of the focus element are accessable from the front of the lens. You can remove the metal cover (it is glued down). Generally you will not be able to re-install the lens barrier, but it can be removed without harm to the camera. When you remove the plastic plate which carries the lens barrier you will see a small metal gear, this is the base of the focus drive.
Jun 13, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX S230 Digital Camera Logo
163 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
