Samsung s2 portable 500 gb hard disk not readable showing it has no files an not able to access it. but it shows up as a drive letter in my computer.
    Brigadier General:
  • 10,406 Answers
Is it still under warranty?
Try connecting it to a different USB port on your computer.
Try connecting it to a USB port on a different computer.
If it still is not detected, then either exercise the warranty,
or disassemble the case, to find two major parts:
* a disk-drive
* a USB-to-disk-drive adapter
Disconnect the disk-drive and connect it as a "slave" disk-drive in some desktop computer, to see if it is recognized, i.e., if it was the USB-to-disk-drive adapter that has failed.
If it still is not recognized, then it is "dead". You could buy a similar disk-drive, install it into the enclosure, and thus create another external storage device.
Posted on Oct 20, 2010
Trekstor external hard drive (DSMNU-S-JM-a) is on (blue light) but the device no longer shows up on the computer. Can't be accessed.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
External Hard Drive Recovery Software
Sep 11, 2012 | Trekstor DataStation maxi m.u SATA 3.5"...
Samsung s2 portable, folders are showed as shortcuts !
OK you harddrive is infected with Malware. This Malware creats shortcuts of each folder and Hide the all those your main folder.
You can scan your Hardrive with fully updated Anti Virus apllication .
To see all your original folder you can enable your Shown hidden File option from your Folder option--View--uncheck show hidden files and folder--and uncheck hide protected operating system files.
Here is the step to unhide your all files and folder in one go.
Step 1:
Click on the below link and download the file "AutorunExterminator"
http://en.kioskea.net/download/download-11613-autorun-exterminator
Extract it --> Double-click on "AutorunExterminator" --> Plug your Hard drive now.
This will remove the autorun.inf files from your flash drive and also from drives.
Step 2:
Click on "Start" -->Run --> type cmd and click on OK.
Here I assume your flash drive letter as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
You can copy the above command --> Right-click in the Command Prompt and
paste it.
Note : Don't forget to replace the letter g with your flash drive letter.
Now press "Enter".
this should solve your problem.
Jul 27, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
I have S2 portable 640gb external hard drive. Do not open the main folder with info and gives me only shortcuts and no way to my folders
Do you think my problem is a cable wear or the device itself
and how can get access to my data
can anyone hepl me
please
May 05, 2012 | Samsung S2 Portable 640 GB USB 30 External...
I have unplugged my Toshiba Canvio 500 GB Basics Portable Hard Drive usb cable while transfering data, and my windows won't detect anymore. And i scan with some tools it says its have a bad sector at...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover lost files.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 05, 2011 | Toshiba Canvio Basics Portable 320 GB USB...
I bought a brand new samsung s2 320 gb external hard drive and use it for several months until consuming about 200 gb of its storage space, I started to have problems in accessing my data. I tried several...
Only store file on the drive not programs. Working program cause to much ware and tare on the external drives.And a partition on a driver that has programs running from it works real hard because it moving file from two sectors of the drive at the same time. Can you be in two places at the same time?
Feb 06, 2011 | Samsung S2 - 1TB USB 2.0 Portable...
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
Lacie HArd drive not accessible
Start > Control Panel > Administrative Tools > Computer Management > Disk Management
Find the drive on the bottom section, right-click it and assign an unused drive letter of your choice. It should then appear in windows explorer.
Jun 30, 2009 | LaCie (300770) 250 GB Hard Drive
USB 2.0 Portable External 200 GB Hard Drive doesn't want show up
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Go Start> Control Panel> Administrative Tools> Computer Management
Select Disk Management under Storage
Look to see if your Drive is listed and what the Status, Layout, Type, and File System it has.
Right mouse click on the dive and click on Explore to see if your files come up. If yes, then perform a Change Drive Letter and Path.
Let me know what the status is.
Feb 10, 2009 | Western Digital Caviar SE16 (WD5000AAKS)...
Computers & Internet Logo
1,173 people viewed this question
David Payne
David Payne
