Question about Belkin F5D7234-4 Router
My linksys connection will not work for any reason.I tryed reseting the router and unplugging it.But its still not working.What might the problem be and how can i fix it?
  • 4,281 Answers
For that you need to configure router again. Follow below procedure. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 10, 2010
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
b>
Dec 28, 2012 | Computers & Internet
Had my wireless router connected, and all worked fine. A friend put a password protection on it. then we got another laptop. When we tried to connect it, it wouldnt work, and now it is all messed up, and...
is broadcast ssid on? should be. . i would default it. hold reset button with pen unplug, plug in while still holding button with pen until all lights start flashing. release pen , wait til power is not flashing then unplug for 10 seconds and plug in. Then setup again before trying wireless security leave it unsecured, then change admin password , reset and try using "network magic" free from the linksys site.
Nov 16, 2009 | Linksys Wireless-G WRT54G Router
Am unable to connect my linksys yesterday itwas fine but now its not working.
Try unplugging your router for 15 second and plug it back in. If this doesn't work, try pressing the reset button on the back of the router next to one of the connection ports. You can use a pencil or a paperclip.
Gary
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless Router Stopped working
Try holding the reset button for 10 seconds, while holding the reset button in, unplug it for 10 seconds, plug it back in, but don't let go of the reset button for another 10 seconds. Respond with any results.
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to internet Model WRT54GS
Hi
I would like to know who is your internet service provider and would like to check if the router is configured with your ISP modem.
To configure for different ISPs here is the link
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US/Layout&cid=1166859761879&pagename=Linksys/Common/VisitorWrapper&lid=6187977881B11
The links are there for setting up with DSL as well as cable modem. Do let me know if its working or not.
Thank you
Rakesh
Jan 06, 2009 | Linksys Wireless-G Broadband Router
Linksys router problem
Try a factory reset on the router, in most cases this can be done by holding the reset button on the unit down for 10 or more seconds. Once this is done you may have to enter any settings into the router again.
Also, try download the latest firmware from http://www.linksys.com and upgrade the firmware on the router.
Dec 08, 2008 | Linksys Wireless-G WRT54G Router
Lost internet connection via cable modem-router-tower
Alright, start with the basic Gateway IP. http://192.168.0.1 That is what i use to access my router's (yeah, we run just a few more computers than normal people) Anyways, If that doesnt work, then the router has been changed beyond a normal spectrum of Ip configurations. Next step is to recontact Linksys and Let them know directly that the IP Address for accessing the router is not working. Meaning you have no Access to the router at all. Almost all routers use the same base access router ip setup. Its rare to find different unless you are like a few people, who find they need to run at least 2 or more routers on the same internet connection because of too many computers.
Otherwise, follow this link:
http://lifehacker.com/software/feature/special-how-to-access-a-home-server-behind-a-routerfirewall-127276.php
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Wireless G Broadband 2.4G Router
Try to reset the router for 20 seconds. There's a reset button at the back of the router. Just press and hold it down for 20 seconds, then unplug the power for 30 seconds, the plug it back in. Now try to reconnect to the Linksys wireless network.
Aug 21, 2008 | Linksys Wireless-G Broadband Router
LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Feb 07, 2007 | Linksys Wireless-G WRTP54G Router
Belkin F5D7234-4 Router Logo
18 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
