Question about HP Office Equipment & Supplies
Printer will not print document - HP Office Equipment & Supplies
Do not buy a hp officejet J5780 3 in 1.(reason) Difficult to turn on and off. Prints in such small font that it is almost impossible to read, and cannot be enlarged.
Posted on Jul 19, 2008
I have a manul I'm wanting to print, but now I don't want to print it. How do I stop it? And also it is printing little boxes (Not the words) What do I do about that?
Runaway print jobs are always a pain! First, power off your printer to stop it from wasting paper. If the power button doesn't work, pull its plug. That will stop the printing for now but your print job will probably restart when the power is resumed.
Whether you are using a PC or Mac, documents that you send to the printer are managed by a printer management service which is responsible for printing documents in the correct order and handling any printer problems that occur. When the printer is turned off, any documents you print will be saved (queued) for printing when the printer starts again. To fix your runaway printing problem you simply need to delete the copy of your large document that is still queued for printing.
On Windows you will see a small icon on the toolbar at the bottom right of your screen that looks like a printer. When you click on the icon you should see a window appear which has the name of your printer in the title bar (e.g. HP Deskjet) and a list of any documents waiting to be printed. To delete a print job, simply right-click on the document name in the list and select "Cancel". When asked "are you sure you want to cancel the document" click on YES and the document will be deleted from your printer queue. Repeat this for all documents in the list until it is empty, then you can restart your printer.
The process on a Mac is similar and even easier since you will see a bouncing printer icon with an exclamation point on it on your toolbar. Click on that icon to see the print queue, click on the document you want to delete and press the DELETE key to remove it.
Jul 30, 2013 | HP DeskJet 6540 InkJet Printer
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
How do I remove cued documents without printing them
Click Start - printers and Faxes - double click on your printer then you will see a list of documents that are queued to print.
Click on the print document you want to remove then click on Document at the top and then click Cancel.
Repeat for other print documents you want to cancel.
Apr 11, 2011 | HP DeskJet 340 InkJet Printer
I want to print a new document but the old document always coming out
This is because - you had tried to print the old documents and that printing sessions were not completed and the documents are in printer buffer. You may switch off the printer - go start - settings - printers and faxes - double click the printer name - you will find some printing requests are there - delete those. Now switch on the printer. Try to print the new document, it will print perfectly. If same thing happen again you do the same steps. But if this problem repeats - you should re-install the operating system.
Jun 12, 2010 | HP DeskJet F4280 All In One Printer InkJet
Samsung CLP-315 colour laser printer - is it true that you cannot print only with the black toner cartridge, if one or more of the colour cartridges is empty? I only need to print black!
Yes, it is true that most of Color printers will not allow you to print document if one or more of the recommended Cartridge of the printer is empty or removed from the printer. for printing only black, the better option will be to change your printer settings while printing a document. ex: when on a document ,and your press Ctrl+P for document printing, there is a option where you can select print color as black and the printer will print your document in Black only.
Feb 05, 2010 | Samsung CLP 315 Laser Printer
Every so often when I try to print a document I
Try reinstalling the printer driver, make sure you uninstall it first.
Jan 10, 2010 | HP OfficeJet G55 All-In-One InkJet Printer
First of all basics:
1. Make sure printer is switched on and connected to computer.
2. Go to Control Panel and then Printers and Faxes. Double click the icon for your printer. When box appears click on Printer then make sure that "Use printer offline" is not checked. If it is, left click to uncheck this option.
3. If there is a queue of documents waiting to be printed then again click on Printer and click on Cancel all documents. This should clear the backlog. Restart the computer and follow step 3 again to make sure the print queue is empty before attempting to print anything.
Jun 10, 2009 | HP Photosmart D7460 Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
60 people viewed this question
Ben Johnson
