Question about Lexmark X4550 InkJet Printer
I had same problem, even if I download de cjb3500_4500en the processo goes on but when I put to configure wifi (orange) they ask me to put a usb cable, but on actives the button do continue if the USB was correct recognize, but I try in two differents computers (one Windows 7 Ultimate 32bits and the other one 64bits). Both windows 7 in differents computers had the same problem, does not recognize the USB, also try to use other cable and does not work. For final sollution I will try to reconfigure the wifi settings by one netbook in windows xp and after that try to conect in windows 7. But I need to do this because the firt time does not work, so I try to reset the wifi settings thinking that will be resolve, but not. So now I had 3 computers (2 windows 7 and onde XP) and nether one is configured.
  • felipe_forum Oct 11, 2010
    I already try those differents drivers because of the operational system. With windows XP I was able to reconfigure the printer on my wifi network, so on the win7 computer I only need to install the driver and configure an existent wifi configured printer. I Do that succesfully, but windows 7 ultimate does not Show any network printer after succesfully install driver. So may I need other printer, i will buy other one. Thanks for the support but this cannot solve the problem
    Genius:
  • 1,087 Answers
You did a nice job trying out other ways to install the printer successfully. However, it's weird that 3 computers are not recognizing the USB connection. Make sure that the USB cable is plugged in correctly (in the right position) in the USB port of the printer.
Next, use the correct driver that is compatible with your computer's operating system. You may need to uninstall the existing software before reinstalling the new one. Instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T. Then, you can download the drivers at:
If problem continues, contact Lexmark technical support.
Posted on Oct 10, 2010
I recently put a pc1 wifi card in my asus k8v-x motherboard the driver cd installed the software okay but now the wifi signal says disconnected and will not work
A COUPLE OF THINGS THAT YOU CAN TRY. MAKE SURE THAT YOU GOT THE LATEST DRIVER FOR THE WIFI CARD. MAKE SURE THAT YOU HAVE A CLEAR LINE OF SITE TO THE WIFI ROUTER. YOU MIGHT TRY A USB TO WIFI ADAPTER INSTEAD. YOU CAN PICK ONE UP AT MOST MAJOR STORES LIKE WAL-MART, OFFICE MAX, BEST BUY, ETC.
IF YOU FEEL LIKE THE PCI CARD IS WORKING OR THAT YOU TRIED A USB TO WIFI ADAPTER CONSIDER GETTING A RANGE EXTENDER TO GO BETWEEN THE COMPUTER AND THE ROUTER IF AND ONLY IF YOUR ROUTER IS IN A DIFFERENT BUILDING.
SOMETIMES THE SOFTWARE CAN PREVENT YOUR INTERNET CONNECTION LIKE FOR EXAMPLE A VIRUS. OR EVEN THE NETWORK IS CONFIGURED INCORRECTLY.
Jan 31, 2015 | ASUS K8V-X Motherboard
Epson L355 - My Printer suddenly cannot connect to Wifi network.
try to put it back to the same place where you took it, if it work, it means that the place where you moved it might have poor signal and if thats the case, i advise you to put a wifi repeater/extender near that wireless printer
Mar 05, 2014 | Epson Stylus Multifunction Inkjet Printer/...
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Gostaria de instalar o software de driver do dispositivo
Já tentou usar o cd do dispositivo ou então no site do fabricante. Se for daqueles tipos Plug and Play ele automaticamente irá pedir o CD na primeira vez que você plugar. Se não aparecer, instale com o CD do dispositivo:
1- Geralmente ao colocar o CD, aparece uma caixinha com passos a serem seguidos do tipo próximo ou next;
2-Você pode ir apertando nos botões proximo(ou next) sem precisar alterar nada pois o padrão já instala certinho, ou se quiser pode alterar algumas coisas durante esse processo de instalação, a sua escolha ;
3- No final aparecerá que o processo foi concluído com sucesso, se não mande a mensagem para cá de erro;
4- Caso conclua com sucesso, verifique se o dispositivo foi instalado ao acessar o gerenciador de dispositivos: Painel de controle-->Gerenciador de Dispositivos;
4.1- Ou então por meio do atalho devmgmt.msc, no executar (acesso por meio das teclas windows+R);
5-Depois tente colocar o dispositivo na máquina.
Estas instruções servem apenas se o sistema for uma das versões do windows.
Mar 01, 2011 | Computers & Internet
My lexmark x4975 will connect by USB but will not connect by wireless. The help assistant asked if any lights were showing on the WI FI indicator - none are lit. How can I make wireless connection?
using your pc/laptop you will have to create a new connection an search for the printer when this has been done, make sure the printers wireless is enabled before attempting to create a new connection
May 03, 2010 | Lexmark X4975 Wireless Color Multifunction...
I can not scan and if I hook up the USB cable my WI FI light goes orange. Lexmark x4530
The WIFI shuts off when you plug in the USB cable. Your printer and computer are still communicating, just not via WIFI. When you remove the cable it should turn back to green. Your scanning trouble is unrelated. This printer does not seem to work with my windows 7 (64x) or for others. We get a "cannot download application list" error.
Jan 23, 2010 | Lexmark X4530 InkJet Printer
Internet on iphone 3g??
Simply go to Settings > Wifi. If Wifi is off, turn it on. You'll see a list of available networks when you're in a hotspot. You can also have iphone tell you when you're near hotspots by turning on "Ask to Join Networks." You won't be able to use the internet when you're not in a wifi hotspot.
Oct 28, 2008 | Apple iPhone 3G
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Lexmark X4550 InkJet Printer Logo
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
