Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
I droped my canon powershot sd 630 now it wont turn on
I was in the store and droped my camera and now it wont turn on at all so i charged the battery to see if it would work and still nothing does anyone know what i could do to fix it
  • cjsfriends Sep 09, 2008
    it turns on but then it go off it wont stay on
    Novelist:
  • 130 Answers
There really is no way to fix this camera unfortunately. You will need to send it in for service. You can set it up online www.powershot.com or call Canon tech support to set it up for service. There isn't much troubleshooting you can do on the phone with no power. If you are beyond your one year manufacturer's warranty, you may also qualify for the upgrade program for deeply discounted newer models for your camera. At last check, yours qualified for the upgrade to the SD750 for $100 whereas the minimum repair cost for your camera will be probably around $99.
Posted on May 31, 2008
How do I unlock my on/off button on PowerShot SD 630
I don't know that there is a lock on the on/off button. Take the battery out for a minute, put it back in and try.
Oct 04, 2014 | Canon PowerShot SD630 Digital ELPH / IXUS...
My sd 600 wont turn on i even charged it nothing happens
Hi, With how old that model is it's likely that the battery isn't able to hold a charge anymore, I'd suggest buying a new battery to correct the problem.
Jun 15, 2011 | Canon PowerShot SD600 Digital Camera
My canon powershot sd 1200 wont turn on i have recharged the battery. what else can i try?
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Jun 01, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Ihave a Canon PS SD 750 digital camera, that wont start, even with a fully charge battery? Is this a battery problem?
I believe your camera's software will have to be updated. You can probably download the update from Canon's website.
Apr 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon sd 630 camera won't turn on
Inside the camera, check the brass contacts where the battery connects to the camera. Clean it with rubbing alcohol (use a cotton swab) and try to turn it on after insterting the battery.
Jan 29, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
