Question about DR Scholl's Scholls 8553 Half Back Cushion Massager
I need an AC Adapter for a DR8682 - DR Scholl's Scholls 8553 Half Back Cushion Massager
  • sleepingcar
    sleepingcar Apr 29, 2012
    I have a ac adapter for dr scoll's dr8682. please make an offer and ill ship it to you. thanx Joseph @ thewrongplanet@live.com
  • 3 Answers
I have a adapter for the dr scholl's dr8682. make me an offer and ill ship it to you. thanx joseph @ thewrongplanet@live.com
Posted on Apr 29, 2012
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
Netbook no power
there are three possible reasons of this issue.
1. Ac adapter
2. Battery
3. Motherboard - you don't want this part to have a problem. It is very expensive.
For this, you need to isolate which part is causing the problem.
1. Remove the battery from your netbook and use the ac adapter only in powering up your computer.
2. If it's not turning on (battery out and only the ac adapter is used), then check your ac adapter for signs of defects. It could be the ac adapter or the motherboard. If you have another ac adapter then you can try it.
3. If the ac adapter works with the computer, then you would need to replace the battery.
Let me know if you have any questions.
David
Jul 13, 2013 | eMachines Computers & Internet
Laptop reboots when ac adapter reattached.
There are three parts in the computer that you need to check.
1. Ac Adapter - it could be defective.
2. Battery - it could be that the battery and ac adapter won't work together because the battery has gone bad. We cannot tell without checking that.
3. Motherboard - it could be that the motherboard's power port is defective.
Do the following so that you can isolate the problem.
1. Remove the battery and use the Ac Adapter only and turn on your computer. If it turns on without any problem, then replace your battery.
2. If the computer still reboots with the ac adapter plugged in (no battery), then replace the ac adapter. or try using a different ac adapter which is compatible with your computer and check if it produces the same problem. If the other adapter produces the same problem, then it's in your motherboard and you need to get it fixed by a technician.
David
Jun 09, 2013 | Computers & Internet
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
Wii console light won't come on
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If it's not working, you can get a *new* NINTENDO brand AC adapter at the following page. Beware of cheaper knockoffs around the internet.
http://store.richspsxparts.com/ofniwiiacadr.html
May 24, 2010 | Nintendo Wii Console
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
The console will not turn on
Unplug the AC adapter from power cord wait 30 min and plug it again.If not help you need to check your AC adapter with voltmeter.If the AC adapter working your wii need service.If not work buy new AC adapter.
Nov 11, 2009 | Nintendo Wii Console
Need an ac adapter for monitor
Adapter? your monitor uses the same cord that you plug your computer in, these cords are all over the place and easy to find.
Dec 06, 2008 | ViewSonic VG800 18" LCD Monitor
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
DR Scholl's Scholls 8553 Half Back Cushion Massager Logo
661 people viewed this question
Top DR Scholl's Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a DR Scholl's Health and Beauty Expert? Answer questions, earn points and help others
