Question about Kenmore Vacuums
Kenmore mod #116 33922300 Serial #D33502445 machine runs-sucks- but brush does not turn. How do I fix this? Thanks Lenny
    President:
  • 1,673 Answers
Could be a problem with a switch, or the brush roll motor. You can go to sears.com, click on the parts link, enter you model number, you will have options to chose what you want to look at, then you get a parts list and picture breakdown, which may help you to find the problem.
Posted on Jun 01, 2008
Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
Jul 07, 2015 | Kenmore Vacuums
My husband sucked up part of a rug. The belt didn't shut off like I thought it was supposed to. Now there is a funny loud hum when the brush is running. There are also some fuzzy disc-like things around...
See if you can take the brush assembly off. There should be a plate and 2 screws. One on each side. You can lift out the brush and get all of the strings and such off of the roller brush. You might have to go a little deeper with it open and see if anything got sucked up the vent way.
Jan 06, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
I have a Sears Kenmore canister sweeper with the power mate, but it no longer has sufficient suction to pick up dirt. I took the machine apart and cleaned it, but it is still not sucking, does this model...
When cleaning the machine, did you do a good job of cleaning the beater brush and making sure it turned freely in the holders on each end? Perhaps a bit of WD40? Also, a new set of belts might help a bit.
Sep 18, 2010 | Kenmore 22812 Bagged Canister Vacuum
The problem started when i sucked a corner of a rug,now it will not **** very much at all??Kenmore upright progressive
This definitely sounds like your belt is broken. The belt is the part that is attached to the motor at one end, and to the roller brush at the other end. If something gets vacuumed up into the brushes that prevents the brushes from spinning, the motor will continue to try to spin the belt, and the motor shaft will then burn right through the belt, or cause the belt to fall off the motor shaft, preventing the brushes from spinning. On an upright vacuum cleaner, if the brushes are not spinning, it will seem like the vacuum cleaner is not sucking well, but in fact the brushes are just not spinning.
To see if the belt is your problem, while the vacuum is plugged, in turn the machine upside down so that the brushes are facing upwards. Make sure that if your machine has a rug/ floor setting that it's set to carpet mode, and now turn the machine on. Does the brush spin? If no, then this is because the belt has either broken, or stretched out so much that it no longer can spin the brushes.
Here's a link to the owners manual for your Kenmore that will walk you through, step by step on how to to replace the belt.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0403213.pdf
I have also uploaded the instruction manual to the main page on Fixya for your Kenmore 34612.
I really hope this helped you. If it did, please help other people who have this vacuum be able to find this repair on Fixya by rating the repair helpful. You may do this by clicking the 4 thumbs up icons in the right hand corner of the repair. If you have any questions about how to replace the belt, or if the belt is ok and something else is wrong, please just use the clarification request form here on Fixya, and I'll be happy to answer any follow up questions that you may have.
Thanks again,
Chris J.
GoVacuum
Apr 09, 2010 | Kenmore 34612 Bagged Upright Vacuum
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Have suction, new bag, brush moving but does not
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
Jun 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
Belt needs fixed after sucking up a soft rug.
if its a canister model there probably is no belt just suction.open the canister and if it has a bag feel the bag ,if it feels kind of hard then the bag is full.take the tool off the end of the hose and turn it on to see if you have suction if you do then the tool is blocked up.take it to the sink and run some warm water through it and maybe use a little brush to clear out the dirt.full bag will cause your vacuum not to have suction or not as much as it should
Apr 09, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 35913 Progressive
Go to sears.com, click on the parts link, enter your full model number, then scroll down and there are several options to clikc on, a parts list and picture parts breakdown are there and if a manual is available, you can get it and parts thru this site. There is a overload switch for the brush roll motor, if tripped then it won't turn. Could be that the brush roll motor is bad. The motor and brush roll are put together as one unit, but you can get the motor by itself.
May 29, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuums Logo
137 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
