Question about Mossberg Marlin Rifle 992m,989,mossberg 640 Scope Mount M8
My model 742 lever action missfires every 3 or 4 rounds.dimple on spent cartraige is much deeper than missfired shells
  • 243 Answers
This may be an indication of a broken firing pin, dirt in the firing pin channel, or an over oiled firing pin/channel. All will exhibit this behavior. A through cleaning is called for, with dis-assembly to follow for parts inspection.
I have also experienced this behavior from a weak hammer spring.
Posted on Oct 14, 2010
Remmington 700 new total of 12 shots action works and sounds perfect but missfires leaves no mark on the primer
tear down the action clean the parts look for damage on each easpecially the spring and firing pin, and also the ejector to make sure a round is properly seated against the face of the bolt, do the rounds eject properly?, you may need to order a new firing pin and or spring from the manufacturer, Remmington online, some manufacturers will send you free parts such as smith and wesson who desnt even charge shiping
Jan 04, 2015 | Optics
PO303 PO353 codes on a 02 lincoln ls missfire?
P0353 - Ignition Coil 3 Control Circuit P0303 is a cylinder #3 misfire.Good chance the the cylinder 3 coil has failed.
Jun 06, 2010 | 2002 Lincoln LS
Check engine light flashing runs rough not firing on all cylinder2000 lincoln navigator with large triton engine Hooked up diagnnostic and it said 1. system too lean bank #2 2. Unable to bleed up fuel tank...
you may try your rotor button and distributor cap. and spark plug wires. try your map sensor also they tend to cause a lot of misfiring if they go bad.hope this helps.
Apr 20, 2010 | Lincoln Navigator Cars & Trucks
I have a ithaca model 49 lever action single shot and it wont eject shells after firing it but it will eject it if i dont fire it,in other words it will eject a live round but not a spent one
there is a lever under the barrel and it is probably worn beyond function or broken off all you need to do is disassemble the gun and replace it. ( get yourself some good brass punches)
Feb 08, 2010 | Guillemot Hercules Dualpix HD 4780428...
Cleo 1.2 16v car feels like missfire light shows
Probably dirty fuel. If you use supermarket fuel try using Shell V-Power or BP Ultimate for a couple of tankfuls. You may find that it's actually cheaper in terms of pence per mile as well!
Nov 28, 2009 | 2006 Renault Le Car
Missfire on number 3 coil on 2001 S type Jaguar 3.0 V6 Sport
Check the igniter module.
I assume you have a ecu code telling you #3 coil is missfiring ?
If so also check the crankshaft angle sensor .
If it is not an error code do a compression test and check the injector.
Hope this helps
Regards
George
Jul 08, 2009 | 2001 Jaguar S-Type
1998 honda civic cel code 71-74
code 71 means #1 cylinder missfire 72 Means #2 cylinder missfire 73 means #3 cylinder missfire and 74 means #4 cylinder Missfire
May 29, 2009 | 1998 Honda Civic
BMW 523i 1999 model
your car is not suppose to idle at 500 rpm . 800 to 950 is the proper idle, unfortunately it is controlled by the computer. have you checked the idle speed control valve? also check the air flow meter
May 28, 2009 | 2001 BMW 5 Series
Mossberg Marlin Rifle 992m,989,mossberg 640 Scope Mount M8 Logo
308 people viewed this question
Top Mossberg Optics Experts
obsteiner
Ted Maxwell
ray gallant
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
