Question about Gateway Profile 5.5 PC Desktop
I have a gateway profile 5.5. Sometimes it will turn on, boot up and then turn itsself off. Sometimes the power putton will not operate but if I unplug the power from the PC, it sometimes will then boot up. I had taken it to the shop but they said they could not do a diagnosis cause it PC would not srtay on but it could be the power adapter, fan, motherboard or all of the above. If it were the power adapter, that would be a matter of just purxchasing it and replacing ( if I could find one, eg AP14AD30 ) but if not that and I could not return, that would be money down the drAIN. Any ideas
  • 4,336 Answers
You can have a shop try the power supply, they probably have some laying around. If it is not the power supply, you should look at system replacement.
Posted on Oct 10, 2010
My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Jun 30, 2011 | Gateway Computers & Internet
My gateway profile 4 desktop will not power on. nothing happens when I push the power button. measured 12v at the computer end of power cord. switch look ok. worked fine yesterday.
Remove the power cord and then take out the battery. Hold down the power button for 30 seconds, then plug in just the AC powercord and try turn the laptop on.
If it turns on let it boot into the operating system and then shut it down and put the battery back in.
Hopefully this will resolve the problem but if it doesn't turn on again with the battery in there is a problem with the battery.
Post back if you need more advice.
Good luck.
Jun 27, 2010 | Gateway Profile 4 All In One (MPN...
My computer won't boot up and keeps going to a dos screen with safe mode and some other prompts. None of these prompts are working, the computer is trying to boot up but gets frozen. It then tries again...
your operating is pretty messed up. what you can do now is to use the Recovery Disk that came with the system to restore the computer to its factory default settings. you need to boot up the recovery disk and perform clean install.
Mar 27, 2010 | Gateway Profile 5 PC Desktop
How do i softboot my profile 5 pc?
very easy login to each of ur user profile one by one click start click run then type msconfig and then go to boot.ini then put check mark at SAFE BOOT
Nov 02, 2009 | Gateway Profile 5 PC Desktop
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
Won't POST or power up
strip it down further to find out the issue. Disconnect all HDs all CD ROMs and remove the memory. Leave the bare minium. Screen and board and see if it boots. If it boots add a memory stick then on next boot if its good add a HD and so on
May 24, 2009 | Gateway Profile 5 PC Desktop
I have a gateway Profile 5. when i cut it on
My understanding is that when you power on your PC, the POST is succesful, but then the system hangs.? If i am correct. There are several reasons this may happen.
1) Boot record corrupt
S) Reformat the harddrive and re-install operating system / replace hard drive
2) General Hard drive failure but boot record instact
S) Replace Hard drive
3) Operating system inoperative
S) Re-install operating system
Most pre-built systems come with recovery disks, you may try this as a solution if available.
When replacing a defective hard drive, or partialy inoperable hard drive, a good policy is to change the drive to slave, and install the new drive as master, this way any data you may be able to recover, can be done after the new hard drive is installed, and an operating system is installed on the new drive.
(POST = Power On Self Test)
May 12, 2009 | Gateway Profile 5 PC Desktop
COMPUTER WILL NOT BOOT
This does not sound like a power supply issuse
Try This:
tap F8 while booting the PC
This should take you to the Advanced Boot option window
Use you up & down keys: Safe mode With Command propmts(Enter)
Operating System (Enter)
Sign in under your user name( or owner)
once at a command prompt (Black Screen)
Tyoe chkdsk /r (Enter)
You will get a message ( This valume is in use would you like to start a chkdsk on reboot (Y) (Enter) Reboot PC
This should start a chkdsk after the chkdsk is complete reboot the PC you should go to you profile (desktop with Icons)
Good Luck
Dr Geek MD
Feb 22, 2009 | Gateway GT5220 PC Desktop
Profile 5 shuts off on its on
Sound either like a Overheating or a Power Supply Unit issue. You may need to clean the thermal gel off the CPU and heatsink with a small amount of rubbing alcohol and apply new gel. Make sure your fans are working correctly and make sure there isn't any dust under the fan on the heat sink it self, as this will cause overheating issues... Also, if you suspect the PSU you can usually get a nicer one than you have now for $50, so it is better to go ahead and replace it if it is old. The pop sound makes me lean more towards the side of power / PSU but this sound could simply be from the hard drive lossing power suddenly.
Dec 11, 2008 | Gateway Profile 5 PC Desktop
Gateway Profile 5.5 PC Desktop Logo
185 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
