Question about Canon imagePROGRAF iPF8000 Printer
I keep getting message "Clean right print head". Can it be done here or do I need service
    Problem Solver:
You can do it - go to menu maintenance-clean printhead
Posted on Oct 14, 2010
  • 565 Answers
Windows XP or Vista
1. Go the control panel and select Printers
2. Choose the applicable printer, right click and choose properties.
3. Click on the tab or button that says "maintenance", "cleaning" or similar.
4. Select which nozzles to clean (only applicable for some printers)
4. Run the program, do NOT perform any other operations until the cleaning process has ended.
5. Print a test page, repeat the process 2-3 times if no visible results are shown.
Posted on Oct 10, 2010
Testimonial: "Thanks. It worked. I'll spread the word (I'm a printer) about your services"
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
I have a canon ipf700 and power went off and now the machine is coming up with an error message of E161-403E. any help will be great
Hold down the roll/media button and the info button while turning on. Wait about 10 seconds and release roll/info buttons. You should get an "S" in the upper right corner; this puts you in service mode.
Push menu then scroll down to maintenance then right arrow to head replacement. Then get out of service mode turn off.
E161 403E means abnormal print head temperature. The print head needs to be replaced. Boot printer into service mode, and from the menu select head replacement.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 03, 2011 | Canon iPF700 InkJet Printer
I have a Canon iPF8000 large format printer and a message comes up saying, "Clean Right P Head". I have cleaned the printhead as it states, but it keeps on showing on the printer screen. Because of this,...
Canon has bad heads for this LFP, it is not unusuall. Every model has this issue, canon even lower the price of head because of this.
When you replace the print head message disapears for some period of time.If Im not wrong I think that is P-01 or 03 print head involved.
Jun 15, 2010 | Canon imagePROGRAF iPF8000 Printer
Epson 9600 print head missing numerous nozzels during test print procedure. Tried power clean several times. Do you have a remedy?
You willl probably need to clean the Pump Cap Assy.
You will need a strong flashlight/clip-on lamp to see what you are doing up in the area you are cleaning.
Move the print head to the left side of 9600. (If you need help with this let me know.)
Use a foam tipped swab slightly dampened with warm water to GENTLY wipe around the seal area of the Pump Cap Assy.
DO NOT USE A COTTON TIPPED SWAB !!!
Dip, Blot, & Wipe. Clean the Foam Swab often to wash off the residue it will pick up. Remenber to keep the swab slightly moist - not dripping wet.
If this does't help, it generally means that the Print Head is also very clogged with gummy/dried ink.
The Print Head cannot be cleaned without removing the Right Side Cover & then removing the Pump Cap Assy. This removing and cleaning is about a 1.5hr-2hr job for an experienced tech. Anyone with moderate mechanical skills can do it though.
Pump Cap Assy cleaning is usually done BEFORE replacing the Print Head.
If the Print Head cleaning doesn't work then a New Print Head is in order.
Hope this helps ! Good Luck !
Jun 10, 2009 | Epson Stylus Pro 9600 InkJet Printer
I have an HP LaserJet 4050 and it needs perform printer maintenance. what should i do
it means it is time to do some preventive maintenance on your unit, or keeping the print heads clean
It is important you keep the printer heads clean. This stops ink clogging the nozzles of the printer, and reduces ink smudge on the paper. This is important for HP , as they don’t always do the best automatic clean in my experience.
To clean the print heads, remove the cartridge, and gently clean the print heads with a soft cotton cloth dipped in a little water. I wouldn’t recommend using tissue or alcohol. Be warned!
Make sure the print heads are dry and then replace the cartridge. By doing this you will expand your printer life and the quality of the printouts.
Prevent the printer from drying up ink by using it
I remember taking support calls around a year ago. People would say I haven’t used the printer for over a year, and the quality isn’t what I expected.
If you use your printer regular this will prevent ink drying up and keep the printer and ink in good condition. Use both Colour and black and white prints weekly to stop the nozzles on your printer getting clogged up, or the ink to simply dry up. Be careful with printer jams Don’t ram the paper out if you have a paper jam. This can damage the printer, which I have seen done many times. Look at guides on the manufactures site, if you don’t have time to do that, remember that you want to get the paper out smoothly. Most HP Printers have a hatch attached at the back that can be removed. You will then have access to the paper wheels, and you should be able to see the paper that is jammed in there. Remove the paper this way, and it is unlikely that you will damage the printer. Power down correctly Turn your printer off when not in use. This can prevent drying of ink and also help keep the printer functioning at high quality. Remember to use the printers power button, and them remove at the plug if need be. Don’t power off if you are in the middle of something. These will just cause problems for you. Clean your printer but don’t over do it IF you perform print ink clean by software or your printer’s hardware, do it once and not over and over. Doing this over and over can cause more damage than good. Clean your printer’s encoder strip monthly to stop quality issues at a later date. Remember if you have low ink to replace immediately. This prevents ink being left in the printer heads and nozzles, and will generally give your printer more life.
hope this helps you, dont forget to mark my solution pls.
Aug 08, 2008 | HP Office Equipment & Supplies
C4180 printer
Hi ,
This product clearly needs a servicing as far as my experience goes . Still we shall go ahead and try to reach the solution or else this definitely needs servicing. I shall explain why -
1. check cartridge on right : if you have replaced the black cartridge and have been using the original cartridges then its an issue with the print heads. The black print head needs to be replaced by the local service centre . There is a blockage in the nozzles of the print cartridge that passes out the ink.
2. slam to the right : if i am not wrong this is the carriage you are referring to. Do the following steps (though i presume you might have done it if you have reset the printer)-
a. pull out the power cable
b. open the cartridge door and hold the carriage with your hand and move it manually 4-5 times left to right with as much speed as possible....there should be no obstruction on the way it moves.....if there is a pin / peice of paper / any obstruction - remove it if you can. The carriage could also slam if the pin of its movement has gone loose and it keeps on slamming uncontrolably. This seriously needs a servicing from the local service centre.
Apr 04, 2008 | HP PhotoSmart C4180 All-in-One Color...
Lexmark X125 keeps saying cover open change cartridge
try to make sure that the clear "ribbon" is situated correctly inside the unit, otherwise it will not communicate correctly with the moving electronics in the cartridge tray
Jan 23, 2008 | Lexmark X125 All-In-One InkJet Printer
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
Canon imagePROGRAF  iPF8000 Printer Logo
734 people viewed this question
old marine
old marine
