Question about LG Televison & Video
I purchased LG ultra slim model tv on 28.10.2009.within 8 months i faced problem of colour patches and the LG service persons changed picture tube for three times.but it is in vain.so they replaced that tv with new ultra slim tv of model no 21FU8RGE3AZ just 5 days before.still we are facing the colour fading problem .what is the remedy and can i verify what they gave us is new tv or not?if yes say the method?
SOURCE: LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Posted on Feb 06, 2007
ChadL777
  • 69 Answers
SOURCE: Color of people's faces in movies played via DVD is now blue since connected to LCD TV
The reason the picture is blue on the DVD is because you have poor video cables running the feed, probably RCA yellow cable im guessing. Get some nice component cables for the DVD feed and it will fix you right up.
Posted on Dec 26, 2007
  • 44 Answers
SOURCE: Philips 42PF7220A/37B shuts after 10-15 min. LED Blinks 5 times
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 50 Answers
SOURCE: Sound but no picture
no bulbs to replace here, i might have better news for you. Toshibas with this time frame has an inverter problem. turn tv on tilt back wards at 45degree angle and flack a light to the screen and look closely if you can see the image the replace the inverter units. to help you see hit menu on remote, the menu is white so will make it more visible. If you did want to replace the inverters they are like 60-80 $ for hte pair and simple to replace.
Posted on Apr 27, 2010
markfreedman
  • 312 Answers
SOURCE: I was told by a
I just now called vizio and read your request word-for-word to their technical support person.
They have been known to fix these sets out of warranty. Although the girl said that she wasn't authorized to make that decision.
She told me to have you call this number 877-698-4946 Tomorrow when their level 3 technicians were available. She says that when you call the 1st tier tech support person will then send you one to these senior techs who can make the decision to cover it under warranty. My personal opinion is that they will take care of you. They say the "squeaky wheel gets the grease" I would go ahead and squeak. There is a link I've provided below to help.
I hope the helps,
Mark
http://www.vizio.com/index.php/support/#warrantydetails
Posted on Jan 19, 2011
Lg ultra slim 21 tv sound picture power
ok ur tv powersupply is ok but horizantal is not working chk ur fbt hot & micronass
Mar 21, 2014 | Televison & Video
Hitachi C21 model.The colours on screen have got scrambled.
It sounds like something has left a strong magnetic field on the face of the picture tube, and that's causing the colour distortion. The electron beams from the tube's colour guns are hitting the wrong spots on the face. There is a degaussing circuit in the TV that tries to neutralise such fields every time the set turns on. Sometimes electrical equipment (particularly motorised appliances like a vacuum sweeper) operating too close to the TV can leave a field too strong for the degaussing circuit to cope with. Or a failed part in the circuit may have made it inoperative.
A hand-held degaussing coil can be used to remove the field. You can purchase one online, or call a TV service technician. It used to be a standard tool to carry.
Another possibility is that the tube has been damaged. There is a very thin metal mesh screen called the shadow mask behind the face of the tube. If this mask has been warped by a strong magnetic field or a mechanical shock (if the set was dropped, for instance), you will see the same colour distortion. In this case, however, there is no repair other than tube replacement. And that is likely to cost more than a new set with parts and labour.
Jul 26, 2010 | Hitachi C21-F200 21" TV
Sharp tv model lc-26sh12u very low vulumn even at max volumn control
Yes, don't buy SHARP, problem solved! SHARP is the worst brand of LCD TV. I had to bring my brand new SHARP TV in for repair within 8 months of buying it brand new, and of course it was no longer under the 90 day labor warranty. Also, every person I know who has a SHARP TV has issues with volume and eventually end up with a black vertical line along the side of the screen within 1 to 2 years. I highly reccomend SONY, PANASONIC, even SAMSUNG, LG or VIZIO. Heck, I'd go with Toshiba or Phillips before I'd ever buy anything SHARP again I was so annoyed with their customer service.
Sep 30, 2009 | Sharp Televison & Video
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Repairing lcd tv.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Feb 17, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Televison & Video Logo
184 people viewed this question
Computer Repairing
Computer Repairing
