Question about Bunn 10 Cup Home Coffee Brewer
What is the best home remedy to clean a bunn?
  • 189 Answers
With the machine turned on and hot, pour in 1 quart of white vinegar and close the lid. Let the vinegar sit for 2 hours. Then flush out the machine with 8-10 decanters of cold water.
Posted on Oct 20, 2010
Overflows the filter area and runs all over carafe & warmer plate
Phil, If brewer has not been cleaned in a while this happens. the 1st link is your manual for down load, page 7,8 tell how to clean to fix your problem, if it has a bad build up may have to run 2x. Also watch video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bunn.com/sites/default/files/care-and-cleaning/43097_0002d01_velocity_brew_manual_english-_bt_st.pdf
Use Care
Bunn Coffee Maker
Apr 27, 2016 | Bunn 10 Cup Home Coffee Brewer
Coffee grounds in bottom, using Bunn coffee filters
only time I have had this problem with BUNN filters is when I got 2 instead of just one .then I refiltered it thru a clean empty filter into another container .
Apr 09, 2016 | Bunn 10 Cup Home Coffee Brewer
Coffee machine every slow
Water discharge tube from heated tank is likely caked with mineral deposits. Bunn makes a de-liming tool for just such a problem.
Google "bunn deliming tool", or buy it on Amazon.
Bunn Deliming Cleaning Spring 01193 0000
Jul 25, 2014 | Bunn 10 Cup Home Coffee Brewer
My coffee pot is very slow and only 3/4 of pot fills
With the machine full of water and still turned on, pour in 1 qt of white vinegar into the top and place decanter on base and close the lid. You will let this sit in the machine for 2 hours. At the end of 2 hours, flush out the vinegar with 8-10 decanters of water.
Jun 29, 2010 | Bunn 10 Cup Home Coffee Brewer
Cleaning
The metal proble is use to clean out the water tubing. Remove your sprayhead and insert the metal rod up in the hole leaving out about 1-2 inches. Then simply twist and turn the rod about 5-6 times. This will remove any lime deposits. Then flush out with 2-3 decanters of water. You can obtain a new manual by calling customer service or going to the website-www.bunn.com going to @home, then products-click on your brewer-and then select use and care manual and you can print it out or view it online.
May 19, 2010 | Bunn 10 Cup Home Coffee Brewer
Cleaning a bunn coffeemaker
the old fashioned way to clean a coffee maker is to run vinager through it then follow with a couple of pots of water that has a bit a baking soda in it.
Apr 18, 2010 | Bunn 10 Cup Home Coffee Brewer
My Bunn is taking forever to brew and the coffee
It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at www.bunn.com @ home, then products.
Apr 09, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Water sprays out in all directions
The solution was that I returned the coffee maker and got a new one. Three months
of working is not enough.
Mar 18, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn G2 is caked and I need to remove burr gear
For this job, you will need detailed instructions. You can download a use and cleaning manual for this Grinder at this adress: http://www.bunn.com/pages/techdocs/manuals/grind.html
Nov 18, 2008 | Bunn Commercial Grade Home & Office Black...
Bunn 10 Cup Home Coffee Brewer Logo
81 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
