Question about GE Profile JKP56 Electric Double Oven
I have a GE profile double door in mount convection oven and the display on the control pad is blank. I have reset the circuit breaker but the display is still blank. The oven light inside when the door is open works. Can anyone tell me what the problem could be? I took apart the top part of the oven door to look at the control panel but I don't see any component that might be burned out. I don't see any fuses either. Can someone point me in the right direction before I have to put in a service call.
  • 68 Answers
SOURCE: ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
Please let me know if this works for you. You can email me at:
Good Luck,
Posted on Feb 04, 2008
  • 86 Answers
SOURCE: GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Posted on Jan 02, 2009
  • 8197 Answers
SOURCE: installing ge profile double oven
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Posted on Jan 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
Posted on Mar 28, 2009
  • 6784 Answers
SOURCE: Flashing locking door light
This is a failed logic chip on the control board. replacing the control board will fix this issue.
Posted on May 27, 2009
The convection fan won't stop even when it's not being used.
Check the switch that power it on. Probably stuck in "on" position.
Nov 18, 2015 | GE Profile JTP56 Electric Double Oven
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    What is blue wire on ge built in oven for
    The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
    This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
    Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
    My oven door lock is in the out position. Oven door won't shut
    Try shutting off circuit breaker for a few minutes to let control module to power down, then turn breaker back on. This may reset the control board back to factory default and retract the lock servo. If this doesn't work then a service tech will be needed.
    Aug 01, 2009 | GE Profile JTP56 Electric Double Oven
    Kitchen Aid Double Convection Oven blows circuit breaker
    the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
    Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
    Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
    Good Luck
    Jan 18, 2009 | GE Profile JT952 Electric Double Oven
    Changed the lite bulb on ge double ge eletric oven and it blew
    There is no reset switch on the oven you blew the breaker in the control panel. you will have to find it and flip it.
    Dec 21, 2008 | GE Profile JTP56 Electric Double Oven
    Top oven doesn't heat.
    We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
    My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
    Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
    Open Questions:
    The convection fan comes on intermittently, starts smoking then goes off. Temperature on the display doesn't move from 100F (then it did). My wife left the door closed while it was on broil last night (not sure how long), and this morning I woke up to the smell of burnt electrical and something (one of the fans...? not sure as it was far earlier than I usually get up) running that stopped when I opened the oven door and restarted when I closed it (I'm thinking it was probably running all night). While at work, I turned the breaker off, then pulled the oven out this evening. After taking some of the metal plates off, I put the power back on and turned the oven on for a 450F bake. I don't know if the little cooling fan at the top of the unit is supposed to go on when I have the top exposed and getting plenty of air; it wasn't and it also had a faint burnt electrical smell. After disconnecting then plugging the fan power connector to the circuit board the fan ran for 10-15 seconds before it started smoking and quit. I checked voltage across the fan leads and there wasn't any. I shut the oven off, tripped the breaker, and let it cool. I then tried testing the fan motor directly i.e. bypassing the oven and using a regular outlet since the motor is rated for 120V. It ran for ~1 minute, then smoked and quit. The smoke is definitely coming from the fan rather than any adjoining wires. Is this a case of the fan AND the control board going south or one contributing to the other's demise? I should add that the clock display has been dimming for a couple of years. UPDATE (2/20): I tried just baking (as opposed to convection baking) and the bottom element did come on (I'd reported earlier that it hadn't... that was because I was using convection baking and that does only heat around the fan... just my ignorance on that one). However, the temperature readout on the display did not move from 100F though it was clearly hotter than that in the oven. I then stopped the baking mode and started convection baking. This time the temperature gauge immediately went to 141F and kept climbing. Resistance at the (room temp) temperature sensor (and at the end of the wiring harness plugged into the control board was ~1100 ohms at room temp (as its supposed to be).
    Feb 19, 2016 | GE Profile JKP56 Electric Double Oven
    See all GE Profile JKP56 Electric Double Oven Questions
    GE Profile JKP56 Electric Double Oven Logo
    49 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
