Question about Sharp R-510HW Microwave Oven
Micro Schematic diagram
I have a R-510FK micro. Am replacing the interlock switch (one of three that is triggered in part by the door opening and closing). There are two terminals on the normally open switch, with two wires connected together on ea terminal. I'm trying to find which two wires go together on either terminal. Connecting the wrong pair causes the micro to operate when the door is open. Where can I find a schematic?
Eldon
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Have you checked behind the operator console? There's usually a tech sheet inside these units that contain a basic schematic and troubleshooting tips.
  • Sharp Master
  • 9,047 Answers
Sharps don't have schematics inside anymore, but I have uploaded the diagram to my site for you.
It's here: http://207.234.249.73/mwd/r510fk_wiring.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
My oven suddenly stopped working
Most microwave ovens have up to 4 micro switches in the door latch, it's a safety interlock. These can go bad, and cause the oven to not function.
Micro switches are pretty inexpensive, and can be replaced. You need to open the oven, and then identify exactly which micro switches you need. Both my current microwave ovens have done this, and I've replaced the bad switches. They work fine now.
Jul 15, 2015 | Microwave Ovens
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
I have a amv6167bds and convection works but no micro
Check the door safety interlock switches ... tiny micro switches found near the latch mech inside the cabinet.
If they are faulty, the oven thinks the door is open and will not turn on the 'heat' in microwave mode.
Thank you for your question @ FixYa.com
Aug 15, 2011 | Amana AMV6167BDS Microwave Oven
I'm experiencing the same exact problem as theresagolde experienced. PROBLEM:Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work...
You can modify a standard, typical micro switch available at many places or, you can get an exact replacement from GE parts placed or you can try www.repairclinic.com or you can try a FixYa.com advertiser.
You are correct in trying the safety interlock switches ... they cannot stand the opening and closing of the door while the machine is running. To improve the live cycle of these tiny switches is NEVER open the door while the oven is operating.
Thanks for your question @ FixYa.com
Jul 28, 2011 | GE JVM1330BW/WW Microwave Oven
My microwave wont turn on. the power works, clock, timer and all electrical is working, it just wont turn on.
Most likely you have an interlock microswitch problem or a latch problem. as you just open or just close the door VERY slowly listen for 3 distinct clicks one for each of the 3 interlocks. Two you will hear as you press the door open button and the last one you will hear as the door just opens or closes. If you do NOT have 3 clicks you have a bad micro-switch.
The micro-switches you can purchase on line here:
http://www.repairclinic.com/Sharp-Microwave-Switch-Parts
Owners manual: (Provided only for telphone contacts in first 2 pages.)
http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R530ES.pdf
I think you just have a simple micro-switch problem. However... if the latch assembly that holds the switch is cracked or broken it will have to be replaced. I have seen the plastic latch assembly fail causing the switch not to work properly.
Thanks for choosing FixYa,
Kelly
Jun 28, 2011 | Sharp Carousel R530EST Microwave Oven
Everything works but it will not heat food
Check the door safety interlock micro switches. Others will po9int to the very expensive magnetron and it might be that but I don't think so. Still others will tell you that it is the capacitor ... and it might be that. If you regularly open the door while the oven is operating, the tiny contacts become damaged from the arcing. When the interlock switches can not longer tell the oven the door is in fact closed, the magnetron will not come on .. and there will be no heat.
It is probably worth removing the cover to check the $2.99 micro switches ...
Make sense?
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My sharp microwave/convection oven come on, clock counts down but it does not heat nor does the turntable turn. About a week ago the breaker was tripped by it I think but it was fine until now. It doesn't...
It sounds like one of the door micro switches is bad. There are three micro switches typically. A primary interlock, a secondary interlock and a monitor switch. It is most likely the primary or secondary interlock switch. You may need to take your switches to a professional appliance shop to determine which one is bad.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 22, 2011 | Sharp R-930AK Convection/Microwave Oven
Microwave lights up but does not heat or turn table when start button is pushed
Check your door interlock switch. Unplug the device, remove the cover DO NOT TOUCH THE SILVER CAN - POTENTIALLY LETHAL. Locate the small, probably black micro switch. Test it with a volt/ohm meter or other contunity tester. It should read "closed" when the door is closed and "open" when the door is open.
If you are like me, you turn the machine off by opening the door. When you do this, power sparks between the small contacts in the micro switch and eventually burns them up. When this happens, the machine thinks the door is open and will not turn on the magnatron - thus - no heat.
Find a replacement switch at a electronics or appliance parts place. You may have to provide make and model for an exact replacement. If you are handy, you can adapt any regular micro switch.
Let me know if this works for you.
A
Sep 14, 2009 | Microwave Ovens
Micro blow circuit
You have a faulty interlock switch. This is one of two or three switches in every microwave that are operated by the door. The interlock switch is wired to blow the fuse if you try to run the oven with the door open. The switch may have gotten knocked out of adjustment (say by slamming the oven door) or its contacts stuck closed. If there are no other problems with the oven, a new switch should clear this up.
Mar 24, 2009 | LG LMV1630 Convection/Microwave Oven
Fuse
The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
Aug 03, 2008 | LG LMVM1935 Convection/Microwave Oven
Sharp R-510HW Microwave Oven Logo
1,402 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
