Question about Kitchen Ranges
I have a DoughPro 1100 manual series Pizza Press. The temperature controller part # 110052 is out and I want to know who repairs them so I don't have to replace it?????
Handle stays down
Doughpro DP1100 Dough Press - YouTube
? 1:27
www.youtube.com/watch?v=QM44NdPY3DQ
Oct 7, 2010 - Uploaded by ZescoVideos This is a how-to video for Doughpro's DP1100 Pizza DoughPress.
ProLuxe DP1100 PizzaPro Pizza Dough Press, Manual ...
www.missionrs.com/doughpro-dp1100-pizzapro-pizza-dough-press-man...
$3,074.60 - ‎In stock Product Description. Efficiently produce crusts that are equal to hand tossed in no time at all with this ProLuxe (formerly DoughPro) DP1100 PizzaPro Pizza ...
Oct 02, 2015 | DOUGHPRO/PROLUXE Dough-Pro DP-1100 - Pizza...
The press will not close all the . will not make contact with the base
Try adjusting your thickness dial. If that doesn't work, take off the housing and make sure your gears and cam ramp are still in order.
May 27, 2015 | Dough Pro DoughPro DP1100 PizzaPro Manual...
Pro Series PS3240 pizza oven , made by PESI. refurbished Middleby.
Call Shimmmer LLC, at 602-447-0304, we specialize in pizza equipment. And deal very closely with PESI ovens. ;)
Dec 06, 2011 | Kitchen Appliances - Others
Does lincoln 1450 series oven do the same job as lincoln 1000 ovn
The 1450 Lincon and the 1450 digital basically does the same things only that the digital is more advance in that it is has mother board whith digital control. it is more acurate in its sttings eg acurate time and acurate temparature setting. It also can give diagnostic massages within the control.
As for your lincoln 1000 series please try and give me the detailed problems, im sure i can help cause i have over 8yrs experinces with lincoln pizza ovens
May 07, 2010 | Lincoln Conveyor Oven - 1132-000-A
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Dough sticks to press
Put a little flower over and under the dough to keep from sticking
Jun 30, 2009 | Doughpro Automatic Pizza Press
Looking for Owners / Operators manual for Acme MRS11 Dough Roller
I looking for a Owners/Operators manual for Acme DMX bench dough roller date 11-17-98 serial 1140
Mar 26, 2009 | Doughpro Automatic Pizza Press
Lincoln Impenger 1100
hellow my name is ash i sale linclion ovens and repair they have only one burner and they only go up to 600 degree F make sure that the impenger plates one on top and one bottem are possion prapley, 2nd set temp at 500 and 530 f time 6.5 m if still under cook blow use plates with holes
Apr 27, 2008 | Lincoln Conveyor Oven - 1133-000-A
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
