Question about Dryers
We have a hoover tumble dryer hnv380 and need afree manual thankyou
yalmer
  • 549 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
SOURCE: Hoover tumble dryer hdv6
my dryer this model does not get warm?
Posted on Jun 19, 2008
vickygomar
  • 460 Answers
SOURCE: Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
Posted on May 15, 2009
rogrrabbit
  • 986 Answers
SOURCE: Hoover Condenser Tumble dryer HSC 170 not heating up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 27, 2009
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
Hoover tumble dryer vhc392T drum not turning. There is power to the machine but the drum wont turn.
check the belt to see if it is broken. check the drive motor to see if it is working.
Jan 10, 2010 | Hoover HDC6 Electric Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
thank you
May 14, 2009 | Dryers
Tumble dryer only tumbles when swhich is held in
It sounds like the centrifugal switch on the dryer motor is malfunctioning. Needs service.
May 13, 2009 | Hoover Dryers
Need a User Manual for Candy CMD146 Type LCE2
Hello.
I can direct you to the site you need to download a copy of user instructions for your washer dryer.
In your browser bar, type -
hoover user manuals
In the drop down list, click on-
hoover after sales service-instruction manuals
Then click on -------laundry
then click on --------washer dryers
In the box enter your model, and you can download the instructions.
Pleas a fixya rating for my solution to your query..
Thankyou.
Jan 30, 2009 | Candy CNW156 Front Load Washer / Dryer
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Jan 23, 2009 | Dryers
Dryers Logo
101 people viewed this question
Top Dryers Experts
