I bought a VIZIO VF552XV2 LCDLEDHDTV. Somehow we did not recieve the proper remote, however the wrong remote did turn the television off and on and did change channels. We took it back however because it did not have the capibility of accessing the Apps. They give us the remote that supposibly goes with the television, however it will not operate the television at all. We tried all the pairing proceedures with no luck. The television simply will not work on our television. What do we do?
  • Joey Miller
    Joey Miller Oct 10, 2010
    If you can give the remote control model/part number I will check it out.
SOURCE: channel buttons (up/down arrows)
Do an autosearch in the setup menu and that should program those buttons. Weird I know, but it worked for ours!
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 29 Answers
SOURCE: Time Warner codes for remote set up
Timer Warner Remote code for Vizio TVs: 1758 1756 0864 0885 1499.
11756 10864 10885
Posted on Dec 12, 2009
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
How do i fix the colors from my tv they are all wrong
Please use your remote to access the video portion of the setup screen. You should find a reset video to factory defaults there or in the initial setup portion. Your manual should point you to the proper section to find these.
Dec 01, 2014 | Vizio Televison & Video
Remote Control Problem
Are Both TVs Vizio TVs? If not it means it has droped the code to the set it is not turning ON
Jan 08, 2010 | V, Inc. VIZIO RP56 Rear Projection...
My Vizio shuts off after 5 - 10 minutes. When I turn it back on, it continues to shut itself off from 1 - 10 minutes. Can you tell me why this is happening and howto fix the problem? Thanks. Model: VIZIO...
Try this: on your remote will be a button labeled "menu" that should contain a list of items you can adjust...I'd look to the automatic timer feature and check to see if somehow this has been set up to turn off the TV.
Aug 11, 2009 | Vizio VW37L 37 in. LCD HDTV
Need remote control code for Sony RDR-VX500
Try these codes. 20533, 20864, 21033, 21904,
21903
May 26, 2009 | Vizio L32 32 in. LCD HDTV
Remote that came with TV doesn't work. are there codes?
It's possible they put the wrong remote in the box. People in the packaging dept can make mistakes.
I have a copy of your manaul. It says nothing about programming the Vizio remote for Vizio TV.
I would call the 1-877-698-4946 support line.
They should send you the correct remote.
You'll need to give them info.
1. Model numbel of the TV
2. Serial number on the TV
3. Purchase price of the TV
4. Model number on the back of the remote
May 10, 2009 | Vizio VW32L 32 in. LCD HDTV
Programming with DirecTV remote
Since the flood of new models is great, your remote will never have the capability to control all brands and models. Vizio (like many others) is a very new name in the marketplace so if they did not choose to mimic the IR system of another, more wide-spread brand, you may never have a code set in proprietary remote such as yours (and mine from Dish Network). Even the 'learning' remote I bought will not accept the control signals from the lousy Ilo we own either. Your provider, DirecTV may have some newly developed partially effective code sets so check the support section of their website.
Apr 22, 2009 | Vizio GV46L 46 in. LCD Television
VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Apr 02, 2009 | Vizio L37 Television
New vizio tv cant get remote to turn tv on
same problem
but it does turn on with a remote.
no other functions
i'ven repl. power supply brd. no help.
i do not hear relay click on
it seems to be in the main brd.
thank you
zbyg
Dec 19, 2007 | Vizio L37 Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
