Question about GE Spacemaker JVM1640SJ Microwave Oven
Right after using the unit ,it stops ,light went out ,no power
  • 10,515 Answers
There are fuses inside the cabinet.You may have access to the cabinet from removing the screws at the back. The whole cabinet would sometimes be lifted whole and all the electrical parts would be exposed.
To remove the cover and access the fuses (and other electrical parts), do as follows:
1. Remove the exhaust fan unit top center rear: remove three screws and reach inside to carefully unplug the power cord, squeezing to release the plastic catches on each side of the plug.
2. The cover you wish to remove is a single piece of bent metal covering the sides and top of the unit. Unscrew all screws passing through this cover; this will be a total of 18 screws located on top, bottom, sides, and rear. Do not unscrew the two screws on the back panel that do not pass through the cover.
3. Slide the whole cover backwards about 3/4" and lift it clear.
There would be couple of fuses you need to check.You could use multimeter for the same. If the fuse is correct, then I was thinking if only the gas sensor is the problem , you should have at least digital read outs. Since there is non, you can check the low voltage transformer.
A small transformer form the power supply board which sometimes have a very fine wire which could just snap open. trace the voltage from the the cable to the fuse and to the transformer.
It is not the high voltage transformer. Please do not be confused. It is the low voltage one. Just to have a low voltage to work on the electronics.
By the time you are tracing the voltage, you could also check all the wiring connections if there is no corrosion specially on the PC board.
Note - You need to take care of all precautions.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2010
MMV4205AAS no light, no fan...then no power
Well part of what you said does sound correct other parts dont make any sense.. Question one is the unit dead now?? have you checked the outlet for power??
have you checked the internal Line fuse to see if it is good??
Does the unit have power to the control board?? these questions need to be answered before we can move on ..As far as the light issue there could be a bad relay on the ctrl board but kets get the unit up and working first
Jan 31, 2008 | Maytag MMV4205 Microwave Oven
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
Went to use and there was no power in unit. was
my kenmore 565 has gone out...no power. We have checked the power supply works. Can we check the internal fuse?
Nov 17, 2009 | Microwave Ovens
EVERY PART OF THE MICROWAVE STOPPED WORKING
There is an internal fuse inside. Need to find the cause for it blowing or it will just go again. Check the monitor switch and door switches. Eric
Aug 08, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Power went out while cooking. Now light, and fan doesn't work either. Could there be a fuse?
Assuming that you have checked the voltage/breaker at the unit, There is a fuse located behind the user interface. You must exercise caution in this area as there is a high potential for harm due to the capacitor having been energized. If you are not comfortable/experienced handling high voltage, then I would strongly recommend calling for service. Hope this helps... Bill
May 29, 2009 | Kenmore 63792 Microwave Oven
Unit lost power
there is an internal ceramic (white) fuse in the microwave just under the cover on the right side
May 04, 2009 | Microwave Ovens
Goldstar
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 27, 2008 | Microwave Ovens
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
