Question about RTO Safety Vacuum Release System - SR-500 Stingl Switch
Mine is to my spa pump. It does not give me an error message, and it does not beep, however, it does shut itself down and then randomly cycles through from "remote" to "timed" to "continuous". It tries to start again in the "continuous" mode, but then shuts off within 3 seconds. My spa is only 1500 gals. But this shuts everything down, heater as well, which isn't good on it to start and stop like that. We cannot figure it out.
Had similar problem with voltage cycling on and off on load side of stingl. I believe its a manufacturer defect. They pushed these things out so fast to meet new law that they didn't have time to test them properly. I'd contact the company for a replacement.
Posted on Jun 25, 2011
MerryChef e6 shutting down during cook cycle
Check your power loose connection. No.# 1 cause of EOC board failing may be in ground return to power hook up
send a model # for more detail diagnostics
Feb 01, 2017 | Ovens
Pump keeps beeping error
...This thing is a medical IV feeder. Nothing to do with pool or spa, if you have this in a pool or spa you should talk to whoever put it in. But as it says on the screen its not reading anything feeding thru its lines. Probably a peristaltic pump and something is clogged into the lines before it or in the tube that pumps itself.
Aug 10, 2015 | Pool & Spa
E96 on intex spa pump
I do not know what that error code is however I can tell you most of those kinds of spa take around 24 hours to heat up.
What model name of Intex Spa do you have?
Rod
US Parts Center
Apr 12, 2014 | Intex Pool & Spa
OH message showing on sundance spa sentry help!!!
If you are seeing OH and FLO codes, you need to shut it down at the circuit breaker, until it can be serviced. It likely needs a new circulation pump and the flow or pressure switch may be failing to shut down the heater causing the boiling
Aug 08, 2012 | Pool & Spa
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
Stops moving
This points to a circuit board defect. Authorized service center only, unfortunately
Aug 18, 2009 | Aquabot Robotic Pool Cleaner
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Hot tub pump stops and control panel says there is a flo problem
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Apr 24, 2017 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
RTO Safety Vacuum Release System  - SR-500 Stingl Switch Logo
151 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
