Monster cable hts2000 mk2 has panel blinking intermittently
  • Anonymous Apr 12, 2009
    same here...anyone with a solution?
Sony tv blinks red light three times then pauses and blinks again
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 19, 2015 | Focus Camera Sony KDL70W850B 70-Inch 1080p...
99 monster misfiring when hot
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in the fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Help Misfire ISSUE Ducati ms The Ultimate Ducati Forum
ducati engine misfire
Ducati 900 M900 Monster 1994 2004 Service Manual PDF Download Manuals...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Apr 11, 2013 | 2002 Ducati Monster 750 i.e.
Our big screen sony tv stopped working yesterday. The power on light is blinking red intermittently and when you push it, it doesn't turn on-no sound or picture. It will stop blinking red periodically, but...
Please try disconnecting all the cables from the TV including the power cables then reconnect them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then service will be required.
Aug 27, 2009 | Sony Televison & Video
Protection light blinks and beeping
it has been through an overload (hence the protection light) and needs its breaker to be reset (look for a poped out button and push it back in) or it needs a new fuse (replace ONLY WITH THE EXACT SAME MODEL OF FUSE or it will either blow too early or too late (or not at all) when there is a surge.
Aug 17, 2009 | Monster Cable Monster Mobile PowerStation...
Alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
Monster connectors not like cable connectors
You were sold an HDMI cable. You need a coax. Wrong cable.
Jan 18, 2009 | Monster Cable (305007B)
Alesis M1 Active MK2 Biamplified Reference Monitor not working
Hi Mate, This seems to be a common problem now, go here looks like you need a new capacitor or two, possibly a resistor aswell depending.
http://www.neufeld.newton.ks.us/electronics/?p=232
Jan 14, 2009 | Alesis M1-Active-MK2 Powered Studio...
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Can't get sound through my hdmi
Try the easisest route first - unplug and replug HDMI cable into same port or the other hdmi port on the TV. Also, make sure the Monster cable isn't HDMI 1.3 - I'm not sure the HDMI ports on this tv are fully compat with 1.3.
If that fails, go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software" - read the specs and see if it says anything about audio loss on HDMI - many Philips have issues with the HDMI ports - they are not broken, but just need a software fix. Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Here are the notes I see:
BX23U-1.5.0.0_03531
Following problems are solved :
• Availability cablecard channel map.
• Improved info in the service menu.
• Improved picture quality and stability on HDMI.
• Installation of channels.
BX23U-1.4.0.0_03081
Following problem is solved :
• Issue related to intermittent video loss is solved.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
138 people viewed this question
 Grubhead
Grubhead
