Question about SanDisk 2GB microSD Memory Card
The Memory card is not detected when locked - SanDisk 2GB microSD Memory Card
  • 43,501 Answers
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Posted on Apr 21, 2011
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
When I put the disc into my camera I get a message that the card is locked. "slide lock to write"
Read this
http://en.wikipedia.org/wiki/SD_card#Optional_write-protect_tab
If after sliding it you still get the same message then the card controler has detected that the memory chip inside it is about to die and has locked it to allow you enough time to recover all the files from it. Once the files are copied junk the card, it's dead.
Aug 04, 2011 | SanDisk 2GB microSD Memory Card
Memory dose not format
Please try the card on another PC if the card is not detected in your PC and if the card cannot be formated then check and see if the tiny LOCK on the side of the card- to protect erase- is put to ON. If so reset and if this wont work still the card is faulty.
May 19, 2011 | SanDisk 2GB microSD Memory Card
I just bought a new sd 2mb sandisk card but computer won't detect it
Are you using a Memory Card adapter? Or are you using the SD slots that are built into your computer?
Go to the 'Start' menu and choose "My Computer"
The card should be there, if not, then make sure that the little 'lock' button isn't set to lock.
A lot of times when you insert the card, it will switch the position from unlocked to locked.
Good luck
Jan 21, 2011 | SanDisk 2GB microSD Memory Card
My memory card not detecting my mobile and in my computer?plz help me
becoz your memory card is either locked or corrupted, if locked insert it in the same phone in which lock key was assigned and get it unlocked
Dec 14, 2010 | Cell Phones
"Card Locked"
Hi!
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 23, 2009 | Canon PowerShot A590 IS Digital Camera
The card is locked
Hi!
Check the lock switch on the SD card. If it's off then it's probably a broken switch inside the camera memory card readed. The memory card readers in cameras have a small switch that detects if the SD card LOCK switch is on. This is a hardware problem, you should give it for a repair - it's not a hard repair - I usually cut off the switch and put a wire accross so the camera allways thinks that the card is not locked.
Hope this helps!
Tom
Jul 30, 2009 | Casio EXILIM Zoom EX-Z150 Digital Camera
Memory card not detected
your card is automatically locked and it is only unlock by using memory card unlocker device but it also format your mmc.other than this you have no choice to open memory card.yes you can use recovery software for recover your important files
Jul 30, 2009 | Electronics - Others
Mann123 help me!
i had the same problem but i had to buy a new one because i dont think you can unlock it.
i have a problem with my kingston memory card too and i need help
Apr 12, 2008 | Kingston flash memory card - 256 MB -...
E6 - memory card locked
remove the memory card from the phone and look for manual lock on MMC adepter and unlock if it is locked.
Feb 14, 2008 | Motorola Mobility ROKR E6 Smartphone
SanDisk 2GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
