Question about Yamaha Rbx374 4String Electric Bass Guitar
What potentiometer is being used in rbx 374 bass volume control..because i replaced it with a500 potentiometer but still its not working..i bought yhe bass second hand,,is potentiometers for active pickups diferrent from passive?
  • Yamaha Master
  • 5,603 Answers
Yes, active use different value pots than passive. The volume control is LIKELY an "audio taper" which can be either an "A" or a "B" marking as there is confusion about the marking. The resistance is likely around 500K ohms down to as low as 50K ohms. The marking MIGHT be something like 504 B or 503 B or the same with the letter "A".
An A500 pot might be only 50 ohms... That would result in very low output. Again, the marking in the industry is not consistent.
Best bet is to get the part from Yamaha. Go to Yamaha America "parts" dept in California. You can search the phone number with Google.
Posted on Oct 11, 2010
Fix for a missing volume control
For what piece of gear?!?!?!?!?!?!?
Dec 11, 2015 | Bass Music
Tip
Electronics spray cleaner
The most common problem with guitar amplifiers
and other electronics that are making noise or cutting out
or sticking and not working correctly is a simple fix...
I use Radio Shack electronics spray contact cleaner
for most of my basic repairs
in the pictures posted I show the basics you need....
some screw drivers, basic knowledge, paper towels,
electronics spray contact cleaner, and a knife
First I carefully remove the nobs (volume control, tone control, etc...)
I use napkins to mask the area and keep from scratching the surface
Then I carefully spray into the (control} and work in back and forth....
the Best way is to spray directly into the potentiometer
that requires access to the internal chassis
on a quality pot there is a Notch that you want to spray into
on a standard pot just spray....
this will repair any scratchy noise or sound that cuts out
on guitar and bass amplifiers,
also can be applied to many other common basic sound problems
I hope this helps someone out?
i could Not upload photos? so please check My link....
https://plus.google.com/105897664234915107933/posts/iHG1R6dpvkU
on Mar 13, 2015 | Music
Preamp changing
This is not program/software error. This is hardware error.
Damage is on the potentiometer. usually caused by a bad contact inside the potentiometer. The most common is the preamp-TYPE potentiometer.Faulty potentiometer can also occur in the other,
depending on what we hear, when (suddenly) the bass sound bigger or smaller, it mean that BASS potentiometer was bad.
Potentiometer must be replaced,because it can not be repaired or cleaned (except,you are experienced in parts repairing).. This is due to the potentiometer is to use a special type.
Jul 14, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
Growl knob not working mxr 288
I would get a can of good electrical contact cleaner and open the unit, spray the cleaner into the back of the controls while rotating them back and forth quickly. This will somewhat clean the control contacts inside eliminating most dust and corrosion. If the control is too old and dirty, it may not work but, I would definitely try. It probably has a special made potentiometer that would be hard to find and replace. They usually have special legs attaching them to the board. I am almost positive that the control is bad or dirty, though. If the sound gets loud when almost all the way up, it does indeed work, just not in a dirty position. That already proves it.
Mar 25, 2014 | MXR M288 Bass Octave Deluxe
My ibanez sr700 bass guitar's volume knob is very
To remove the knob, there should be a small hex key or allen screw on the side of the knob. Just loosen the screw. You don't have to remove it.
To tighten the nut properly, you may have to remove the back panel of the bass and hold the potentiometer from the other side. If allowed to turn too much, it could mess up the wiring.
Feb 26, 2013 | Music
Hi, I have an RBX 374 and I cannot get any sound from it. I have got the wiring scheme but the wiring looks O.K. Some say it might be the pre-amp. Does anyone know what could be the problem...
i dont' see where this model has active pickups (guessing this is what you mean by pre-ampped).
The issue can be in a few places.
1) the strings could be too far from the pickups and the instrument needs to be tuned.
2) the pickups are bad
3) your jack is bad
4) the cable is bad
5) your equilizers are not corrected
6) your volume control is turned down or damaged
7) your amp is damaged
this is a small list of the basic possibilities.
Mar 29, 2011 | Yamaha Rbx374 4String Electric Bass Guitar
We have a yamaha guitar which needs repair, the serial numbers don't appear to mactch in my quest for a tech.manual. They are: QJ0093226 (EG-112 GPBL H) Can you help ?
Here is the link you need:http://europe.yamaha.com/en/products/musical-instruments/guitars-basses/el-basses/rbx/rbx374/?mode=model The manual is down loaded in pdf. Scroll down the page. The serial number has nothing to do with the manual only the model number applies.
Oct 18, 2010 | Yamaha Rbx374 4String Electric Bass Guitar
My bass guitar wont connect to my amp.
Assuming that the amplifier is functioning properly, I suspect that the problem is either in the cord, the plug socket on the bass, or the volume control potentiometer. First, I would try another cord that is known to be in good condition (ALWAYS plug the cord into the instrument FIRST). Second, carefully remove the cord receptacle plug from the bass and examine the solder joints (check for loose wires). Third, carefully remove the plate that holds the volume and tone pots. Examine these controls for loose wires or faulty solder joints. CAUTION: If solder joints are found to be the culprit, care must be taken to correct this problem. If too much heat enters the pot, it can be ruined!
Dec 31, 2009 | Music
Problem of marshall g80rcd, volume drop when i play
It sounds like your volume control is dirty. You will have to disassemble the amp enough to get access to the volume potentiometer which is soldered to the circuit board. There will be a square hole in it that you can spray some contact cleaner into the control. Use only contact cleaner as anything else could damage the control. Use a small squirt and rotate the shaft. If this doesn't solve the problem you may have to replace the control. While you have it apart, examine the solder side to make sure all the solder joints are perfect especially those on the controls. A bad solder joint can also cause the same problem. Before you take the amp apart unplug the power with the amp on and the volumes turned down. This will discharge the capacitors so it will be safe to work on. I hope this helps.
Oct 31, 2009 | Marshall Mg15dfx 15-Watt Combo Guitar...
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Yamaha Rbx374 4String Electric Bass Guitar Logo
283 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
