Question about Quasar QP3-18CTM FM Radio
I'm looking for manual or operation specs for quasar qp-3 fm pen radio
How do I change my cd clock radio to AM
probably doesnt have AM option. You have high quality CD sound and high quality FM sound, they don't let you have bad quality AM. Having said that it does.
LISTENING TO THE AM/FM RADIO 1.
Press the ALM OFF/SOURCE button to select the FM or AM mode.
2.
Press the
/MIN button or
/HR button step by step to tune to the desired radio stations.
3.
Press and hold the
/MIN button or
next radio station in the direction of the search. The search operation simply finds stations with
strong signals. Stations with weak reception can only be tuned in manually
THIS MANUAL IS FOR THE 201
Onn ONB14AV201 Product Manual Product Features View
Jul 09, 2017 | Audio Players & Recorders
How do you access the fm radio on a Samsung GT-C3300K please. The user manual only mentions the mp3 player. Thank you.
To listen to the FM radio
1. In Menu mode, select FM radio.
2. Select to start the FM radio.
3. Select Yes to start automatic tuning.
The radio scans and saves available stations
automatically.
The first time you turn on the FM radio, you will be
prompted to start automatic tuning.
4. Control the FM radio using the following icons
and keys:
You can find the User Manual that show the FM Radio in this link. Look on Page 25 for the Radio Instructions
Apr 21, 2011 | Samsung Cell Phones
Trying to find a quasar fm pen radio manual
first insert headphones then insert cells given (LR44) +side on the spring and - on the other end .PRESS the seek button and a channel will be found .press reset ,the radio will return 99MHz
Oct 10, 2010 | Quasar QP3-18CTM FM Radio
Specification of the radio
The ICOM IC-R3 is a handheld wideband receiver (NOT a 2-way radio) that covers 0.495-815.995 and 902-2450.095 MHz in AM, FM wide, FM narrow, and TV modes. It offers 450 channels in 8 banks. This scanner/receiver does not receive SSB, digital, or trunked transmissions, and the TV band is useless in the USA since all transmissions are now digital.
If you're an old hand, this might be the perfect scanner/receiver for you. Otherwise, you should probably avoid it, as it's complicated/difficult to operate, lacking in many features that are standard in most scanners, and generally high-priced. The R3 and its big brother, the R5, were dismal failures in the USA scanner market.
For more detailed info/specs, you can download/print the R3 product brochure and instruction manual here:
http://www.icomamerica.com/en/downloads/Default.aspx?Category=129
BillB
Jan 19, 2010 | Icom IC-R3 Two Way Radio
Can't find the voltage specs for terk 9330 tower fm antenna
Product Specs: General: Product Type Radio antenna Recommended Use Indoor Width 3 in Depth 16.9 in Height 3.5 in Color Black Localization English Antenna: Wave Band AM, FM / FM: 87.5 - 108 MHz, 540 - 1700 kHz Impedance 75 Ohm Gain Level 42 dB Amplifier Built-in Included Accessories Connector coupler, impedance transformer Connections: Connector Type 1 x FM antenna ¦ 1 x AM antenna Power: Power Device Power adapter - external Manufacturer Warranty: Service & Support 1 year warranty Service & Support Details Limited warranty - 1 yearlet me know how this works out for u
Jan 31, 2009 | Audio Players & Recorders
Quasar QP3-18CTM FM Radio Logo
47 people viewed this question
Top Quasar Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Quasar Audio Player and Recorder Expert? Answer questions, earn points and help others
