Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
The hoover agility that I borrowed is not sucking up water, I don't have a manual, can anyone help. I probably put it together wrong.
  • 377 Answers
You will find this URL of help:
http://www.ereplacementparts.com/search_result.php
Please provide a Thumbs Up if you find this solution helpful.
Paul
Posted on Oct 10, 2010
Why is my hoover agility not sucking up water
It is likely the recovery tank lid is loose. This means the suction is loosing. Worst case is the suction pump is faulty.
Look at this manual in the troubleshooting section.
http://hoover.com/file/655/
Sep 03, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Agility
check for an obstructed lint filter behind your dirty water tank. if this isn't it please post back.
Aug 31, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose to stress. It certainly cannot last for many full bends of the handle.
We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
UPDATE: I McGuyverized it myself with a dremel cutoff tool, some vinyl tubing, some 2-part epoxy, and a lot of faith. It sure isn't pretty, but it sucks again. :)
May 30, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover agility wont suck
There are 2 filters and if either one gets clogged, it will not suck up the water. One is from the bottom, it is red, pull it out far enough to clean it. The other one is behind the dirty water tank, remove the tank and you can see it on the wall covering the inlet for the suction. Clean it off, you should have suction now.
Feb 13, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Agility steam cleaner
Sounds like you have a broken water line, or it just came off. You would have to remove the top housing to get to the water lines. Or at the bottom of where the solution tank sits on, is the reservior asm. there are lines going there also. Bottom of the tank, the valve is stuck open. The trigger on the handle is stuck pushing down on the reservior asm.
Jan 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Suction
Opening that door and attaching the hose will let the suction go thru that hose. So if when you removed the hose, if that door isn't closed tight will cause you to have a suction problem It has to seal and have no leaks. The other thing when be a problem with the recovery tank not sealing when you put it back on. Other then that, any air leak will cause a suction problem.
Apr 19, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
143 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
