Question about Linksys Wireless-N WRT150N Router
Cordless phones and wireless connection
We lose wireless internet everytime some uses the phone we have digital phone and high speed internet. We have tried changing the channels on the phones but don't know how to change the channel on the router How do we change the channel on the router?
You have to login to the router. Once logged in you will go to your wireless tab and and will be able to adjust the channel that the router is transmitting on.
Posted on May 31, 2008
Will your internet box interfear with a cordless phone if they are to close together ?
A wireless router and wireless network adapters can have interference issues with cordless phones. It depends on the network adapter frequency and the cordless phone's frequency. Most problems will occur with a phone that uses 2.4GHz. This frequency will interfere with 802.11b/g networks and single-band 802.11n wireless signals.
A DECT cordless phone operates at a different frequency from the 802.11g and 802.11n single-band and will not interfere with a wi-fi network with those modes.
However, some routers and wireless adapters can use the 5GHz range (802.11n and 802.11ac, among them). These can have a problem with cordless phones that use 5.8GHz. However, there is a simple solution to avoid much of the interference at 5GHz. First determine the frequency range of your phone by getting the FCC ID from the base of the phone. Then use Google or another search engine to find "FCC ID Search Form". It has been at http://transition.fcc.gov/oet/ea/fccid/ in the past. The first three characters are the Grantee ID for the search form. The rest is the product ID. Look for the SAR report for the phone and then (probably on the second page) find the TX frequency range and the Max RF output power tested. Now go to the wireless router's setting page and make sure that it is using channels that do not use the same frequency and power range. See http://bradsfavorite.com/avoid-interference-5-ghz-wifi-5-8-ghz-cordless-phones/ below the 5GHz Wifi Frequencies for a table with the channel and frequency ranges for routers.
Once everything is clear, you can visit ScanmySpeed.com and have an internet speed test to ensure that there is no disturbance in your connection.
Nov 01, 2014 | Lands Phones
When my Xbox is plugged in my phone line doesn't work.
The Xbox 360 Console is not compatible with a dial up connection or a phone line. It will only work with an Ethernet connection and some sort of high speed internet. You can also use the wireless built in the new 360s or purchase a wireless adapter for the older models if you have a wireless router with high speed internet in your home already.
Mar 04, 2011 | Microsoft Xbox 360 Console
I keep losing my internet connection when I use the wireless router. When I disconnect the wireless router, internet works great but when I reconnect it it keeps cutting out. I unplug it for ten seconds...
Try changing the channel to 11. Cordless landline phones often interfere with the default router channel. It can even be your neighbors phone that is conflicting.
Feb 06, 2011 | D-Link DIR-615 Wireless Router
How do I change the channel on my belkin router so that I do not lose internet connection when I try to use a cordless phone? I have an Acer laptop with a wireless connection. Vtech cordless phone and...
Click here for General Instruction about changing wireless chanel
You can also visit the Belkin Official siteto download the product user manual for the complete instruction about router settings.
Jan 03, 2011 | Computers & Internet
I have wireless connection with a 2 wire modem and every time my home phone [ cordless ) rings or someone is on it ,, i lose my internet connection . Ive put a splitter on the cords and everything and it...
The reason why your experiencing that problem was the cordless phone and the router that youre using has the same 2.4Gz frequency.So everytime the phone rings it interupts the wireless signal what i can suggest is if the phone is in between the computer and the router or if the phone is near the router move it away so that it wont interfere the wireless signal
Thanks for using Fixya.
Aug 02, 2010 | 2wire (1000-000057-000) Modem
We have high speed internet service with a netgear WGR614 connected for wireless service... I keep losing connection and the PC attempts to automatically reconnect, any help? Thanks.
Make sure the latest wireless card driver is installed in the computer.
Locate the wireless router higher and away from walls. Locate the wireless router away from cordless phones and microwave ovens these can cause interference.
You could be getting interference from other wireless access points or wireless routers in your area. Check the wireless broadcast channels in your area, and select one that is unused or one that has the weakest signal strength.
Dec 19, 2009 | NetGear WGR614 Wireless Router
Everytime the phone rings my wireless connection goes away. I am also unable to secure this network. the model number is f5d8235 4
Your phone is using the same frequency as the wireless router (2.4GHz). It would be very difficult to prevent this unless you change:
1. Phone to corded system.
2. Change phone to cordless DECT (5.8GHz) system
3. Change network router from "G" series to "N" series.
Sep 25, 2009 | Computers & Internet
Lose internet connection when phone is in use
Your cordless and wireless mode is running on same frequency.
You can do couple of things...use the wireless mode in b instead of g in the router.
Else use a different cordless phone which runs in 5.8 or 6.0 frequency.
Hope this helps.
-Pankaj
Mar 26, 2009 | Belkin (54G F5D7230UK4) Wireless Router
When the cordless phone is in use the internet on the laptop cuts out can anyone help
Assuming you have DSL - Verify that you have a DSL filter in the phone line that leads to the base unit of the cordless phone.
Assuming your laptop connection is wireless - See if there is a frequency conflict with your wireless internet and the cordless phone.
If neither of these suggestions help, please reply with specific details regarding your internet connection (Cable/DSL) and the connection of the laptop
Dec 01, 2008 | Lands Phones
Need help
You are losing your internet connection because of interference with the wireless router and cordless phone. Try either switching the channel on your router or on your phone. That should fix your problem.
Apr 15, 2008 | Dynex Enhanced-G Wireless Broadband Router
Linksys Wireless-N WRT150N Router Logo
82 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
