Question about Kohler K-10416-BN Fort½ Single Control Kitchen Faucet with Side Spray...
I open the faucet and no water comes out. I close it and wait I hear a pop then I turn the water on and it comes out.
  • 4,350 Answers
Look at washer issues in the shut off valve before the faucet. these have washers that stick and block flow. If not, you have to remove the faucet and disassemble, looking for particulate matter, but your description sounds like cut off valve issue, pretty common.
Posted on Oct 10, 2010
  • waterman23 Oct 10, 2010
    thank you Guru for your help I'LL try that
How do i stop air pop when hot water faucet first turns on?
kinda sounds like a form of water hammer. try shutting of water at house main. open lowest and highest faucets to let them drain for a bit and introduce air into system to replace air in any anti water hammer setup you might have. then close them, turn water on. open faucets to get air out. and see if that improves the system. good luck
Mar 14, 2015 | Plumbing
How to fill the water heater in a 2014 cougar 19rb
I have had two different travel trailers and both of the water shut offs were behind wood panels between the kitchen and the back bedroom
Jul 31, 2014 | Keystone 2014 Cougar Xlite 19RBE
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
How to clear Major plumbing clogs
I am assuming that you are referring to a calcium or rust build up in the water heater.
If you are having this issue you will need to turn off the water to the heater. You will need a garden hose, access to a outside water soucre, cold water is fine.
Shut off the gas or power to the hot water heater before starting.
Now you will need to place the garden house on the drain fitting on the water heater, placing the end of the hose outside and lower than the drain valve. Open the valve and drain the heater, you will need to open a hot water faucet to help drain the heater. I don't suggest opening the TPR ( Temp Pressures relief )valve due to the fact that they sometimes leak or don't reseal after opening them.
Hopefully the drain valve is not clogged, you should hear and see water exiting the garden hose.
If you are not getting any water from the drain valve you are going to have a challenging task.
If no water is coming out, my recommendation is to get the required tools to remove the hot water line from the top or side or the heater, also a few towels to soak up water A bucket is helpfull also.
remove the hot water line, then you will have to use a small hose to siphon the water from the tank. Once the tank is empty you can then remove the drain valve and replace it.
once you have replaced the drain valve you should ensure that it's closed and use a Gallon of CLR. Poor this into the water heater through the hot water outlet where you removed the pipe from. Now make sure the faucets are closed and replace the hot water line. You can now turn the water back on to the water heater.
After a few minutes open a hot water faucet to let out any air until water flows out, than close the faucet.
Let the water heater set for a few hours, then drain the tank!
when the tank drains, close the drain valve again and refill the water heater. Once again open a a hot water faucet and let the air out till the water heater fills. Again let sit for a hour.
At this point open a hot water faucet at the farthest point from the heater and let the water run for 5 min. , than close it and move to the next closest faucet and repeat until all faucets have been opened and run for 5 minutes.
If you still have a slow flow in a faucet, you may need to repeat the CLR step.
I also suggest that you remove all faucet screens and clean them.
If you still have a clog than you are going to have to remove or replace a piece of water line in the house. The blockage may be hard to find but if you have access to most of the pipe or it's visable you may be able to hear the blockage with the water on. Otherwise this will result in using some water line taps and a pressure guage to find the blockage.
Oct 17, 2013 | Mountain Plumbing Water Heaters
No water coming out hot water faucets cold is fine.
First check to see if the main faucet to your hot water system is turned on. It could be someone has closed it. It is located around the bottom of your system. If that is open, water should be entering the tap.. To check this shut the main faucet at your water system and using a wrench loosen the connection from the faucet to the system and slowly open the faucet to see water comes out.. If it does that means the main water serivce to the system is fine .. You can also check this at the system by gently opening the outlet connection which should be at the top of the system , ensure that the main faucet At the bottom of the system is closed, once the connection at the top has been loosened slowly open the faucet to see if water comes out of the outlet.. If it does then the problem is from the system to your household faucets.. Could be a crushed water line . Also check to see if your hot water faucet is not Jammed. Sometimes the rubber inside the hot water faucet could be blocking the water if the faucet has been recently over tightened when closed.. Hope all goes well
Jun 04, 2013 | Kitchen Ranges
Heater comes on with water
please see the next step:
he pilot light may be out or may not stay lit. There may not be enough hot water, or the water may be too hot. The water heater may leak or be noisy, or the hot water may be dirty.
A problem with your water heater may be due to overwork, not mechanics. If your water heater holds less than 15 gallons per family member (tank volume is stamped on a metal plate affixed to most water heaters), consider a larger unit or staggering your use of hot water.
Drain a hot water tank:
  1. Turn the gas-control knob to off and close the gas-shutoff valve.
  2. Close the cold-water supply valve and open a hot-water faucet in the house to speed draining.
  3. Attach a garden hose to the drain valve and run it outside to a drain. If the heater is in the basement you may need to run the hose to or through a sump pump.
  4. Open the drain valve and allow the tank to drain.
  5. Once done, close the drain valve, open the cold-water supply valve, and open any nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full; close the hot-water faucet.
  6. Once the tank is full, turn on the gas and relight the pilot.
Jul 31, 2012 | Heating & Cooling
Have a pegasus shower faucet an it knocs every time you turn the hot water on in any part of the hause
Sounds as if you have air in the pipes.
To solve this you will need a piece of hose that will fit over the ends of your hot and cold faucets in the kitchen (or other lowest faucets in the house) - fix it on tightly with hose clips and open both faucets fully. Wait 5 minutes or so before turning off hot water faucet first.
If that hasn't cleared it repeat the process but after 5 minutes turn on your shower faucet and see if it splutters as the air is forced out. You may have to do this with other faucets in the house too. Close each one off once the water runs evenly without air in it.
If that doesn't work you will need to drain your hot water system down completely. Turn off water supply at the hot water cylinder (or rising main if you have a tank-less system) and open all faucets until water stops flowing. Close each faucet about 2/3rds then turn on water supply again. Wait for each faucet to get a slow but steady flow. Going round each faucet in turn gradually open each on a little bit more until all are running fast and even and all the air has spurted out. Now go round each faucet in turn closing each one down a bit at a time until they are only dribbling a small amount. Turn all faucets off.
Feb 17, 2011 | Plumbing
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Hot water coming out of overflow pipe on my vulcan everhot water
Assuming you are talking about the temperatur/pressure relief valve, it is stuck open.
1. Turn off gas or electric to water heater
2. Close water supply to water heater
3. open hot water faucet on nearest fixture to depressurize hot water system.
4. close tpr valve (you may have to push in on the center spine. It may be resistant to closing from sediment. If so, opening and closing several times may solve that issue.
Once you get the tpr valve closed, close the faucet and open the supply valve. If the tpr stays closed, go ahead and turn on the gas/electric and re-light pilot and turn on control etc.
If the TPR blows again, you will need to replace it. YOu can buy a new one at any plumbing supply store. Shut down the heater again, drain a bit of water out using the valve on the bottom of the tank. there is probably copper pipe connected to the TPR valve which you may have to cut or maybe can just unscrew. The TPR threads out of the tank, install the new valve (make sure to use pipe dope or teflon tape.
Jan 04, 2009 | Water Heaters
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
Kohler K-10416-BN  Fort½ Single Control Kitchen Faucet with Side Spray... Logo
370 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
