Question about Brother PE-150V Computerized Sewing Machine
Have a brother pe-150 embroidery machine. it is grabbing the fabric and thread is wrapping around the bobbin. can you help me? I changed the needle, tried different bobbin , thread, cleaned casing
  • 106 Answers
SOURCE: picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Posted on Mar 30, 2008
SOURCE: My Brother PE 150 will
My pe-150 embrodery machine is not grabing the tread right since I changed the needle out it keeps promping me to check my threading
Posted on Nov 16, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: What bobbin do I need
the brother bobbin number is SA 155 it is only available at a Brother Dealer.
Posted on Nov 22, 2010
  • 460 Answers
SOURCE: I have a brother pe 770 and the bobbin will not
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Posted on Dec 15, 2010
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
I have a Brother 750D innov-isi think he tenchion
If the thread is pulling through the top of the fabric slacken off the top tension to about 4 and tighten the bobbin tension slightly by turning the screw on the bobbin case about a quarter of a turn clockwise and test.
Apr 06, 2010 | Brother SE-270D Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
My Brother PE 150 will not pick up bobbin thread. I changed needles cleaned it etc. nothing helps.
Sep 07, 2008 | Brother PE-150V Computerized Sewing...
Problems
I had the same problem, but I then got a shorter bobbin. what is happening is that the bobbin is too tall and the tread is getting stuck in the bobbin. It helped me from trashing my machine.
Aug 25, 2008 | Brother PE-150V Computerized Sewing...
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Problem with my machine
l have a pe-200 brother machine and the needle won't go down and is making a noise can anyone help .l have checked belt and that's fine thanks
Dec 11, 2007 | Brother SE-270D Computerized Sewing...
Brother PE-150V Computerized Sewing Machine Logo
117 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
